Cruise_2_xs Posted July 15, 2011 Report Share Posted July 15, 2011 When on road trips, I like to listen to the truckers on the CB for road info, etc. My edge Limited has a glass roof, not a metal one, which creates two issues: 1) A magnetic mount won't work on the glass top, and I'm not sure a suction cup would be strong and/or reliable enough for freeway speeds. 2) Use on a glass top may or may not require a "no ground plane" type antenna. Has anyone solved these problems successfully? Thanks. Quote Link to comment Share on other sites More sharing options...
flyerjmr33 Posted July 15, 2011 Report Share Posted July 15, 2011 When on road trips, I like to listen to the truckers on the CB for road info, etc. My edge Limited has a glass roof, not a metal one, which creates two issues: 1) A magnetic mount won't work on the glass top, and I'm not sure a suction cup would be strong and/or reliable enough for freeway speeds. 2) Use on a glass top may or may not require a "no ground plane" type antenna. Has anyone solved these problems successfully? Thanks. Stick the magnetic antenna to the right side of the hood. Quote Link to comment Share on other sites More sharing options...
tpm419419 Posted July 16, 2011 Report Share Posted July 16, 2011 When on road trips, I like to listen to the truckers on the CB for road info, etc. My edge Limited has a glass roof, not a metal one, which creates two issues: 1) A magnetic mount won't work on the glass top, and I'm not sure a suction cup would be strong and/or reliable enough for freeway speeds. 2) Use on a glass top may or may not require a "no ground plane" type antenna. Has anyone solved these problems successfully? Thanks. You can try a hood mount, may even go on the hatchback http://www.rightchannelradios.com/hood-roof-cb-mounts-83/ Quote Link to comment Share on other sites More sharing options...
wilsons66604 Posted July 18, 2011 Report Share Posted July 18, 2011 When on road trips, I like to listen to the truckers on the CB for road info, etc. My edge Limited has a glass roof, not a metal one, which creates two issues: 1) A magnetic mount won't work on the glass top, and I'm not sure a suction cup would be strong and/or reliable enough for freeway speeds. 2) Use on a glass top may or may not require a "no ground plane" type antenna. Has anyone solved these problems successfully? Thanks. Have you tried the area in front of the glass roof (next to antenna) or on the rear spoiler? Quote Link to comment Share on other sites More sharing options...
