19" ford flex wheels fit?
RaulB
hey guys i found some nice all aluminum 19" ford flex wheels and tires for a great deal and was hoping they will fit.. i have not bought them yet because i want to make sure they will fit...
has anyone done this swap or know if they will bolt up to a 2010 edge with no problems?
thanks
-Raul
thanks
-Raul
What is the tire size? if not correct it could mess up your speedo-not read properly, just a thought.
ill find out what the tire size is...
my concern was that maybe the offset is not correct.. they both use the same bolt pattern though
I was also interested in this and came across this thread from a Flex forum: http://www.fordflex.....php?f=3&t=3653
In short, they might fit but you need to be aware of possible hub size differences. According to this thread, your hubs might be larger than the Flex's.
If our hubs are larger than the Flex it will benefit us. All you would need to do is take the wheels to a machine shop to bore it out to match the hub. Wouldn't cost much at all.
  • 2 months later...
old thread but they were sold before i could get there to buy them... but... i found some other ones... here is what i gathered as the info on the wheels
Rim Structure: One Piece Rim Width: 8
Offset: 39 Number of Bolts: 5
Rim Diameter: 20
im not 100 percent sure if these will work.. if the offset is incorrect is it safe for me to get some small spacers?
from what i have gathered the offset on the OEM wheel sis 45. if i go with a 39 off set does that just mean that they will stick out a lil bit more?
Edited by RaulB
