jimmkx2k11 Posted July 9, 2011 Report Share Posted July 9, 2011 Hello, I'm aware of the autolock feature when you are in the vehicle and drive away but... Is there a way to have the vehicle autolock all doors after I put it in Park and exit the vehicle with the fob in my pocket? I believe GM calls this passive locking and I like it. Thanks Quote Link to comment Share on other sites More sharing options...
Hankster Posted July 10, 2011 Report Share Posted July 10, 2011 Anythings possible when you have money. The answer would be no. Quote Link to comment Share on other sites More sharing options...
richy Posted July 10, 2011 Report Share Posted July 10, 2011 It was doing that to me when I had the autolock feature turned on and I didn't like it so I turned it off. Quote Link to comment Share on other sites More sharing options...
rajtech113 Posted July 10, 2011 Report Share Posted July 10, 2011 or press the last two keys on the drivers door external keypad at the same time, locks all doors if the key is not in the car. Quote Link to comment Share on other sites More sharing options...
cal3thousand Posted July 10, 2011 Report Share Posted July 10, 2011 On 7/10/2011 at 2:43 AM, rajtech113 said: or press the last two keys on the drivers door external keypad at the same time, locks all doors if the key is not in the car. It will lock your keys in there too. I leave my IA fob hidden in there if I go swimming or something. Quote Link to comment Share on other sites More sharing options...
jimmkx2k11 Posted July 10, 2011 Author Report Share Posted July 10, 2011 Thanks. I could also touch the outside of the door handle to lock that car but... I would need to remember to do either of these things. An automatic lock system would be better. Thank again. On 7/10/2011 at 2:43 AM, rajtech113 said: or press the last two keys on the drivers door external keypad at the same time, locks all doors if the key is not in the car. Quote Link to comment Share on other sites More sharing options...
cal3thousand Posted July 11, 2011 Report Share Posted July 11, 2011 On 7/10/2011 at 3:00 PM, jimmkx2k11 said: Thanks. I could also touch the outside of the door handle to lock that car but... I would need to remember to do either of these things. An automatic lock system would be better. Thank again. Well, if you really want the feature and find out that it cannot be programmed in, know that you could have it accomplished with a couple relays and a capacitor or timer. OR buy an aftermarket alarm with the feature built-in. Are you electrically inclined? or are you looking for someone to install something for you? Quote Link to comment Share on other sites More sharing options...
jimmkx2k11 Posted July 11, 2011 Author Report Share Posted July 11, 2011 Thanks for the info. I am not electrically inclined. I'm used to this autolocking feature and now must remember to lock the vehicle. Maybe this will be a factory feature in the future. Jim On 7/11/2011 at 2:34 AM, cal3thousand said: Well, if you really want the feature and find out that it cannot be programmed in, know that you could have it accomplished with a couple relays and a capacitor or timer. OR buy an aftermarket alarm with the feature built-in. Are you electrically inclined? or are you looking for someone to install something for you? Quote Link to comment Share on other sites More sharing options...
ELation Posted October 8, 2011 Report Share Posted October 8, 2011 (edited) On 7/11/2011 at 12:53 PM, jimmkx2k11 said: Thanks for the info. I am not electrically inclined. I'm used to this autolocking feature and now must remember to lock the vehicle. Maybe this will be a factory feature in the future. Jim I thought it "autolocks" when I walk away. I came here for the same question because it wasn't locking. Edited October 8, 2011 by ELation Quote Link to comment Share on other sites More sharing options...
