wciesla09 Posted July 7, 2011 Report Share Posted July 7, 2011 Has anyone else experienced this: You let off the gas while driving and instead of just coasting, you feel almost like the car is downshifting, though the RPM's don't move much. It feels like the transmission is slowing the vehicle down intentionally. I am not sure if this is part of the design, maybe it has something to do with fuel efficiency - or if this is a problem with my transmission. Any thoughts? Quote Link to comment Share on other sites More sharing options...
akirby Posted July 7, 2011 Report Share Posted July 7, 2011 On 7/7/2011 at 7:04 PM, wciesla09 said: Has anyone else experienced this: You let off the gas while driving and instead of just coasting, you feel almost like the car is downshifting, though the RPM's don't move much. It feels like the transmission is slowing the vehicle down intentionally. I am not sure if this is part of the design, maybe it has something to do with fuel efficiency - or if this is a problem with my transmission. Any thoughts? This could be downgrade assist - are you tapping the brakes when this happens? Quote Link to comment Share on other sites More sharing options...
wciesla09 Posted July 7, 2011 Author Report Share Posted July 7, 2011 On 7/7/2011 at 7:12 PM, akirby said: This could be downgrade assist - are you tapping the brakes when this happens? no just letting off the gas Quote Link to comment Share on other sites More sharing options...
akirby Posted July 7, 2011 Report Share Posted July 7, 2011 On 7/7/2011 at 7:33 PM, wciesla09 said: no just letting off the gas Torque Converter might not be unlocking. I'd have the dealer check it. What year/model? Quote Link to comment Share on other sites More sharing options...
cal3thousand Posted July 7, 2011 Report Share Posted July 7, 2011 (edited) On 7/7/2011 at 7:33 PM, wciesla09 said: no just letting off the gas Sometimes, I feel the same thing. I think it's the car understanding you are on an incline of some sort and cutting the injectors. EDIT: just found this link that indicates that the Edge will occasionally put an additional load on the alternator on coast to charge your battery and (presumably) reduce it's use on acceleration. Wonder how much truth is in there. http://bartowfordnew.../2011-ford-edge EDIT2: after some more reading, it seems fuel cut as well as a clutched "smart" alternator all help to give the Edge it's 19/27 EPA rating. Edited July 7, 2011 by cal3thousand Quote Link to comment Share on other sites More sharing options...
mrdave Posted July 8, 2011 Report Share Posted July 8, 2011 Mine definitely has this behavior, although it's not extremely noticeable. I have found that if you depress the accelerator even just a tiny bit, it will coast as you would expect. I haven't driven an automatic vehicle for a while so I just thought this was normal behavior. Quote Link to comment Share on other sites More sharing options...
wciesla09 Posted July 14, 2011 Author Report Share Posted July 14, 2011 I read this in the manual which appears to explain it: "your vehicle has been designed to improve fuel economy by reducing fuel usage while coasting or decelerating. when you take your foot off the accelerator pedal and the vehicle begins to slow down, the torque converter clutch locks up and aggressively shuts off fuel flow to the engine while decelerating. This fuel economy benefit may be perceived as a light to medium breaking sensation when removing your foot from the accelerator pedal" Quote Link to comment Share on other sites More sharing options...
akirby Posted July 14, 2011 Report Share Posted July 14, 2011 On 7/14/2011 at 7:33 PM, wciesla09 said: I read this in the manual which appears to explain it: "your vehicle has been designed to improve fuel economy by reducing fuel usage while coasting or decelerating. when you take your foot off the accelerator pedal and the vehicle begins to slow down, the torque converter clutch locks up and aggressively shuts off fuel flow to the engine while decelerating. This fuel economy benefit may be perceived as a light to medium breaking sensation when removing your foot from the accelerator pedal" PLEASE tell me the manual doesn't say "breaking" Quote Link to comment Share on other sites More sharing options...
cal3thousand Posted July 14, 2011 Report Share Posted July 14, 2011 On 7/14/2011 at 8:42 PM, akirby said: PLEASE tell me the manual doesn't say "breaking" At least it's only a "light to medium breaking sensation" Quote Link to comment Share on other sites More sharing options...
akirby Posted July 15, 2011 Report Share Posted July 15, 2011 On 7/14/2011 at 9:19 PM, cal3thousand said: At least it's only a "light to medium breaking sensation" So it's only cracked a little bit maybe? Quote Link to comment Share on other sites More sharing options...
AXCL Posted July 15, 2011 Report Share Posted July 15, 2011 On 7/14/2011 at 9:19 PM, cal3thousand said: At least it's only a "light to medium breaking sensation" I think the key word is "sensation", Translation: You get "sensation" your car is broken, but it's not...it just feels that way. Quote Link to comment Share on other sites More sharing options...
cal3thousand Posted July 15, 2011 Report Share Posted July 15, 2011 On 7/15/2011 at 8:34 PM, AXCL said: I think the key word is "sensation", Translation: You get "sensation" your car is broken, but it's not...it just feels that way. Thanks for pointing that out... I totally understand now Quote Link to comment Share on other sites More sharing options...
marcw Posted July 17, 2011 Report Share Posted July 17, 2011 Akirby is right and my take on this is that other/older cars still supply gas more gas than the edge does while the pedal is not engaged. In theory you take your foot off the pedal means you want to slow down, why supply gas. Quote Link to comment Share on other sites More sharing options...
Grey Posted July 17, 2011 Report Share Posted July 17, 2011 Spell check doesn't help when you mistype brake as break. And our minds are trained to read thru misspelled words, sometimes even when proofreading. Some errors will slip thru. One trick I used to use was to read what the agency personnel had done backwards just to avoid the tendancy to read over an error. Glad there is a great explanation for the new feel for coasting. I havn't been in a new one yet, but won't be surprised if it happens now. Quote Link to comment Share on other sites More sharing options...
akirby Posted July 18, 2011 Report Share Posted July 18, 2011 On 7/17/2011 at 6:05 PM, Grey said: And our minds are trained to read thru misspelled words I don't have a problem with typos but when people use the wrong word it just drives me nuts. Quote Link to comment Share on other sites More sharing options...
richy Posted July 18, 2011 Report Share Posted July 18, 2011 On 7/18/2011 at 1:31 AM, akirby said: I don't have a problem with typos but when people use the wrong word it just drives me nuts. Me too my pedantic friend! Quote Link to comment Share on other sites More sharing options...
