Cant change radio stations
Good Morning...
This morning on my way into work, I could not change the radio stations on the screen. I could change them on the steering wheel, but it was like the screen was locked. I have had my car for 2 weeks. Did I accidently lock the screen out?
Thank you!!
Beckie
Welcome to one of the random issues with Sync. You might try disconnecting the negative cable on the battery for a few minutes, then reconnect. That will cause a cold boot of the Sync system. Hopefully then, all will come back normal. You may need to have the software updated as well. Check with your dealer and see what version you have. The latest version is 2.8, but it has problems as well.
Or pull and replace fuse 29.
