Adding subwoofers to factory radio
I am hooking up my subs into the factory radion but i am have a hard time with the remote wire off the amp . i dont know where to tap it into to get the power when the car turns on can anybody help me?
Get a test light and goto the fuse panel. while turning the key on and off find a fuse terminal that goes on when the key is turned on and tap into that fuse... very little current is drawn for a amp remote turn on so there is nothing to worry about in regards to blowing fuses. just make sure u tap into the side of the fuse that is goin on and off, not the constant side... good luck
