Wheels question
Jay442
Will a 20" 2008-2011 rim fit my 2007 mkx ... Wanted to get another set !!' please help
I don't see why not.
What's the bolt pattern and offset?
Ford's bolt pattern for CUV and sedans/coupes is pretty standard at 5x4.5in AKA 5x114.3mm ... Make sure that the offset is for FWD vehicles and you're good. So Fusion wheels would work, MKX, MKZ....
Check this site for more help about Ford stock sizing: http://www.bolt-patterns.com/Ford-Bolt-Patterns.php
  • 3 years later...
While the bolt pattern and offset may be the same the center hole is not. I tried to install a set of wheels from a Flex, which are also used on the Lincoln MKS. They fit just fine on the rear, but the center hole wasn't large enough to fit the Edge's front brake rotors.
