Uncle Buck Posted June 6, 2011 Report Share Posted June 6, 2011 We bought an 08 Ford Edge LTD AWD used the factory code does not work on the keyless entry? we have the factory code card in the glove box we are able to lock it by pressing the last 2 buttons, but unable to unlock or set new codes... it's never worked since we bought the vehicle... any ideas would be appreciated... Quote Link to comment Share on other sites More sharing options...
akirby Posted June 6, 2011 Report Share Posted June 6, 2011 On 6/6/2011 at 2:14 PM, Uncle Buck said: We bought an 08 Ford Edge LTD AWD used the factory code does not work on the keyless entry? we have the factory code card in the glove box we are able to lock it by pressing the last 2 buttons, but unable to unlock or set new codes... it's never worked since we bought the vehicle... any ideas would be appreciated... Check each button to make sure they all work. Perhaps one of them isn't working (one of the first 3 since you already tested the last two). If they all seem to work (the pad lights up when you press it) then you may just have the wrong factory code. Do a search on the forums for the location of the keycode. It's printed somewhere in the vehicle. Quote Link to comment Share on other sites More sharing options...
richy Posted June 7, 2011 Report Share Posted June 7, 2011 (edited) Akirby's advice is good. I think I remember reading that the code is either on the inside of the fuse cover or somewhere under the hood. I will see if I can find the info. Here ya go; http://www.fordedgeforum.com/index.php?/topic/6723-factory-code-for-keyless-entry/page__p__53721__hl__%2Bfactory+%2B__fromsearch__1&do=findComment&comment=53721 Edited June 7, 2011 by richy Quote Link to comment Share on other sites More sharing options...
akirby Posted June 7, 2011 Report Share Posted June 7, 2011 On 6/7/2011 at 1:03 PM, richy said: Akirby's advice is good. I think I remember reading that the code is either on the inside of the fuse cover or somewhere under the hood. I will see if I can find the info. Here ya go; http://www.fordedgeforum.com/index.php?/topic/6723-factory-code-for-keyless-entry/page__p__53721__hl__%2Bfactory+%2B__fromsearch__1&do=findComment&comment=53721 Fuse cover sounds right but I wasn't sure since this has been discussed on numerous vehicles and it's in different places. Quote Link to comment Share on other sites More sharing options...
Uncle Buck Posted July 2, 2011 Author Report Share Posted July 2, 2011 Ended up being on the inside of the fuse cover... not sure why the card in the owners manual had a different #... Thanks for the help guys Quote Link to comment Share on other sites More sharing options...
