How to Fix Ford Edge Sunroof Problem
My Edge 2007 Model carries 28K miles. The Vista sunroof quit closing to the end position all of sudden today, and stayed open by 6-8 inches. The outdoor temperature in Vancouver today is 70F with sunshine, the Sunroof got his problem after I have driven 60 miles. Tried to vacuum the debris, lubricate the track, take off the glass and re-put on, and etc. Nothing worked. I then follow the initialization process, it worked. The sunroof can be closed to the very end. Thinking to share with fellas with same problem.
  • 2 months later...
I just got a 2007 ford edge. Well not my vista roof is not working properly. It will open fine but when I close it it will not close all the way. It stays open about 12 inches. I have greased the track and checked it for debris. It just stops. Doesn't even try to move after that point. PLEASE HELP!!!!!
