rwolson Posted June 3, 2011 Report Share Posted June 3, 2011 Many encountered selecting Sirius channels after Sirius Channel changes in early May. A fix exists on SyncMyRide under Communities>Sync Annoucnements>Sirius Voice Command Update File You'll need to login and download the zip file. Note, the zip contains a Readme file with instructions re: unzipping the file, etc. I installed the fix early today. My system didn't reboot like the Readme mentioned, but went into a diner for breakfast and after restarting the car I found the patch fixed my problems. I can now successfully select and choose the correct channels. Quote Link to comment Share on other sites More sharing options...
jackson5 Posted June 3, 2011 Report Share Posted June 3, 2011 I've never used any "voice commands" ever.. Is that like a big part of the 2011 Ford Edge? Should I try it out? I just installed that SIRIUS patch for the hell of it. No problems. A?fter USB installed I turned the ignition off for 30-45 seconds. Then I turned ignition back on. Screen stayed black for about 10-15 seconds. Then the Sync boot up screen appeared. Then it said completing updates. After about 30 seconds it was all done. Quote Link to comment Share on other sites More sharing options...
richy Posted June 3, 2011 Report Share Posted June 3, 2011 This whole issue confuses me. I never did anything and my presets never changed nor did the voice commands change the station they went to. I wonder why others have had problems? Quote Link to comment Share on other sites More sharing options...
rwolson Posted June 4, 2011 Author Report Share Posted June 4, 2011 This whole issue confuses me. I never did anything and my presets never changed nor did the voice commands change the station they went to. I wonder why others have had problems? I first wonder too about people mentioning the problem then I ran into it. Basically, if a Sirius channel moved to a new channel the system selected the old channel number when you used Voice commands. For example, Bluesville moved from 74 to 70. If I gave the command to select Bluesville, I'm lisenting to Met Opera. If I gave the command for Met Opera I heard some other off beat station; only voice commands encountered the problem. Quote Link to comment Share on other sites More sharing options...
ciggy Posted June 4, 2011 Report Share Posted June 4, 2011 Thanks for the update rwolson. I applied the update and it worked like a charm - Sirius now tunes stations correctly as per my voice commands. Quote Link to comment Share on other sites More sharing options...
