twincam1450 Posted June 3, 2011 Report Share Posted June 3, 2011 The interior lights & vanity mirror lights, are not working properly. They will not come on when the doors open or when you click the unlock button, nor will they come on when you roll the Dimmer switch to the ON position. However they will come on when you toggle each switch individually. I have checked the fuses and they are all good. I saw somewhere that this is a common problem. Any ideas? Thank you, Quote Link to comment Share on other sites More sharing options...
carbonedge+ Posted June 4, 2011 Report Share Posted June 4, 2011 I have never experienced this problem. When you say 'they will come on when you toggle each switch individually' what switches are you referring to??? Quote Link to comment Share on other sites More sharing options...
carbonedge+ Posted June 5, 2011 Report Share Posted June 5, 2011 Sorry, I understand what you mean now. But I'm not sure why it's operating the way you've described. Quote Link to comment Share on other sites More sharing options...
rad48 Posted June 5, 2011 Report Share Posted June 5, 2011 I had the opposite problem. Couldn’t turn the dang things off – and couldn’t keep the parking lights from coming on every time a door was opened. It interfered with star-gazing and stalking my ex. Seems that some model-years allow you to turn these functions on/off by pressing various buttons at certain intervals. If so, it’ll be in your owner’s manual. For my 2010 Edge, the Factory Trained Service Advisor, at my Authorized Ford Dealer, initially told me it couldn’t be changed. But, after arguing with him, he agreed to have a Knowledgeable, Factory -Trained, Service-Technician take a look at it. Conclusion: It could be changed, but since the change would require an actual connection to an actual computer, the cost would be $118. Quote Link to comment Share on other sites More sharing options...
Matthew Scott Posted February 10, 2015 Report Share Posted February 10, 2015 i know this is old but did anyone ever resolve this i have the same issue Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted February 11, 2015 Report Share Posted February 11, 2015 (edited) Do the interior lights come on when you rotate the dimmer switch to the dome lamp position? If yes, it's probably one of door ajar switch(s) hanging up for dirt, old grease, etc. Try opening each door and spraying WD-40 into each door latch. Then open and close each door several times to free it up. If the interior lights do not come on with the dimmer switch, the smart junction box probably has a fault in it. (Secondary options include broken wires, corroded connections, etc). Edited February 11, 2015 by enigma-2 Quote Link to comment Share on other sites More sharing options...
Joe HanSik Ha Posted February 19, 2015 Report Share Posted February 19, 2015 (edited) http://www.ar15.com/forums/t_1_76/1497680_Police_andamp_quot_Dark_Modeandamp_quot__on_Ford_vehicles___Upfitters_please_have_a_look.html police dark mode Edited February 19, 2015 by Joe HanSik Ha Quote Link to comment Share on other sites More sharing options...
DPMS Posted March 2, 2018 Report Share Posted March 2, 2018 I have a 2014 Edge. A couple of weeks ago I left the lift gate open all night. Now the dome lights will not come on when I open any of the doors. The map lights work when you turn them on manually and the puddle lights and vanity mirror lights work. I checked all the fuses and I disconnected the battery for a while in hopes something would reset. I checked all the bulbs and they all work. I opened and closed all the doors many times with no success. Does anyone have any ideas? Thank you, Quote Link to comment Share on other sites More sharing options...
woozin Posted June 11, 2018 Report Share Posted June 11, 2018 I've seen previous posts a while back about this issue, but have seen no solution posted. Here's the problem: About 2 years ago, I went to hit the switch on my dash that turns all of the interior lights on. The interior lights flickered and then went off. I hit the switch a couple more times and every once an a while, the interior lights would flicker. Eventually, the lights were completely unresponsive. Since then, the switch will not turn the lights on at all. I have replaced the switch console and the issue persisted. The lights work if you use the point-of-use switch, but they don't come on when you open the door or use the dashboard switch. I've checked the fuses and relays and all are fine. The dealer looked at (although I don't have any confidence they investigated thoroughly) and they don't have a clue. Any suggestions? Thanks. Quote Link to comment Share on other sites More sharing options...
mvan231 Posted January 22, 2020 Report Share Posted January 22, 2020 On 3/2/2018 at 4:58 PM, DPMS said: I have a 2014 Edge. A couple of weeks ago I left the lift gate open all night. Now the dome lights will not come on when I open any of the doors. The map lights work when you turn them on manually and the puddle lights and vanity mirror lights work. I checked all the fuses and I disconnected the battery for a while in hopes something would reset. I checked all the bulbs and they all work. I opened and closed all the doors many times with no success. Does anyone have any ideas? Thank you, Did you ever find a fix? 1 Quote Link to comment Share on other sites More sharing options...
Eli M Posted May 16, 2021 Report Share Posted May 16, 2021 Did you happen to find a fix by any chance? On 1/22/2020 at 4:37 PM, mvan231 said: Did you ever find a fix? Meant to do this. Quote Link to comment Share on other sites More sharing options...
mvan231 Posted May 16, 2021 Report Share Posted May 16, 2021 11 hours ago, Eli M said: Meant to do this. Never had experienced this in our 2016 Quote Link to comment Share on other sites More sharing options...
omar302 Posted May 17, 2021 Report Share Posted May 17, 2021 (edited) 18 hours ago, Eli M said: Did you happen to find a fix by any chance? 18 hours ago, Eli M said: Meant to do this. I am just guessing, since what turned the lights off was the battery saver, maybe the relay is stuck. Try to disconnect the vehicle's battery to see if it resets it. Edited May 17, 2021 by omar302 1 Quote Link to comment Share on other sites More sharing options...
Eli M Posted May 17, 2021 Report Share Posted May 17, 2021 8 hours ago, omar302 said: I am just guessing, since what turned the lights off was the battery saver, maybe the relay is stuck. Try to disconnect the vehicle's battery to see if it resets it. I took it to the dealer and they did that to no avail. I’m guessing it has to be more wiring related? Their service manager could not figure it out. Quote Link to comment Share on other sites More sharing options...
FireworkIce Posted May 15, 2022 Report Share Posted May 15, 2022 On 3/2/2018 at 4:58 PM, DPMS said: I have a 2014 Edge. A couple of weeks ago I left the lift gate open all night. Now the dome lights will not come on when I open any of the doors. The map lights work when you turn them on manually and the puddle lights and vanity mirror lights work. I checked all the fuses and I disconnected the battery for a while in hopes something would reset. I checked all the bulbs and they all work. I opened and closed all the doors many times with no success. Does anyone have any ideas? Thank you, Anyone find a fix for this? I’m having the same issue. Had the hatch open for a while switching out the interior lights for leds. I swapped them all and everything was working as normal and I left the hatch open while cleaning up and the hatch, dome and map lights turned off and won’t come back on when I open the door. The 2nd row switched lights and front map lights both work when turning on the switch. Hatch, dome, and map lights won’t turn on when door opens or using the dome light switch. Checked and fuses look good, specifically checked 4 and 12. Tried disconnecting battery and touched the cables to get rid of static charge but still same problem. Puddle lights under the exterior mirrors were replaced with leds at the same time and both work on remote unlock and when the door is opened Anyone find a fix for this? I’m having the same problem Quote Link to comment Share on other sites More sharing options...
omar302 Posted May 15, 2022 Report Share Posted May 15, 2022 2 hours ago, FireworkIce said: Anyone find a fix for this? I’m having the same issue. Had the hatch open for a while switching out the interior lights for leds. I swapped them all and everything was working as normal and I left the hatch open while cleaning up and the hatch, dome and map lights turned off and won’t come back on when I open the door. The 2nd row switched lights and front map lights both work when turning on the switch. Hatch, dome, and map lights won’t turn on when door opens or using the dome light switch. Checked and fuses look good, specifically checked 4 and 12. Tried disconnecting battery and touched the cables to get rid of static charge but still same problem. Puddle lights under the exterior mirrors were replaced with leds at the same time and both work on remote unlock and when the door is opened Anyone find a fix for this? I’m having the same problem I would suggest disconnecting the battery for ~10 minutes to reset the electronics. Quote Link to comment Share on other sites More sharing options...
FireworkIce Posted May 15, 2022 Report Share Posted May 15, 2022 12 hours ago, omar302 said: I would suggest disconnecting the battery for ~10 minutes to reset the electronics. Thanks for the suggestion. I tried disconnecting it for about an hour but no luck. Anything else I can try? Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted May 15, 2022 Report Share Posted May 15, 2022 Try charging the battety. May be low from leaving the hatch open (ran mine low in the same way). Quote Link to comment Share on other sites More sharing options...
FireworkIce Posted May 15, 2022 Report Share Posted May 15, 2022 2 hours ago, enigma-2 said: Try charging the battety. May be low from leaving the hatch open (ran mine low in the same way). Thanks. I’ll try that. Is the thinking the battery saver sees the battery below a certain threshold so it hasn’t reset to “normal?” Quote Link to comment Share on other sites More sharing options...
Haz Posted May 16, 2022 Report Share Posted May 16, 2022 The following descriptions of the interior lighting system come from relevant sections of the 2014 Edge Workshop Manual... Good luck! Interior Lighting – Description and Operation The interior lighting system consists of the following components: Interior/map lamps Puddle lamps Cargo lamp Front scuff plate lamps Vanity mirror lamps Glove compartment lamp (MKX) Instrument panel dimmer switch (integrated into the Front Lighting Control Module (FLM) ) Door ajar switches (integrated into the door latches) Liftgate ajar switch (integrated into the liftgate latch) (manual liftgate) Liftgate/Trunk Module (LTM) (power liftgate) Body Control Module (BCM) Ambient lighting harnesses with LEDs HVAC module (located under the instrument panel near the steering column) The interior lighting system consists of: Courtesy lamps Demand lamps Ambient lighting (if equipped) Battery Saver NOTE: Time-out is 1 minute if the vehicle has less than 80 km (50 miles). To save battery voltage, the BCM provides automatic shut-off of the courtesy and demand lamps after a time-out period when the ignition is off. A timer in the BCM starts when any of the following occur: the ignition changes to off any door or liftgate becomes ajar while the ignition is off an UNLOCK button of the Remote Keyless Entry (RKE) transmitter is pressed while the ignition is off a valid keypad code is entered while the ignition is off the instrument panel dimmer switch is used to turn the courtesy lamps on while the ignition is off When 10 minutes have elapsed, the BCM automatically shuts off voltage to the lamps. The timer restarts (voltage is restored if the BCM is in battery saver mode) if any of the following occurs: the ignition changes out of off any door or liftgate becomes ajar the UNLOCK button of the Remote Keyless Entry (RKE) transmitter is pressed a valid keypad code is entered the instrument panel dimmer switch is pressed Courtesy Lamps The courtesy lamps subsystem consists of the door ajar switches (integrated into the door latches), the interior lamps, the cargo lamp, the puddle lamps, the scuff plate lamps, the FLM , and the BCM . Illuminated Entry The illuminated entry requests the dimmable backlighting, the parking lamps and the courtesy lamps to illuminate when the ignition is off and a door or liftgate is opened, the RKE transmitter UNLOCK button is pressed, or the vehicle is unlocked using the keyless entry keypad. If no doors are open, the illuminated entry requests the lamps off after 25 seconds have elapsed, the ignition switched out of off, the RKE transmitter LOCK button is pressed, or the vehicle is locked using the keyless entry keypad. Interior Lighting Delay The interior lighting delay feature provides temporary illumination of the dimmable backlighting, the parking lamps and the courtesy lamps after the doors are opened and then closed. The interior lighting delay feature keeps the lamps on for a period of 25 seconds after all the doors are closed. If during the 25 second delay time the BCM detects the ignition has been switched out of off, or if the vehicle is locked using the RKE transmitter or the keyless entry keypad, the lamp illumination is discontinued. Illuminated Exit The illuminated exit requests the dimmable backlighting, the parking lamps, and the courtesy lamps to illuminate for 25 seconds after all doors are closed and the ignition is turned off. The illuminated exit deactivates when the ignition transitions out of off, a door or liftgate becomes ajar, or 25 seconds have elapsed. Theater Lighting The theater lighting feature ramps-up the courtesy lamps over 0.7 second when courtesy lamp activation is requested. The theater lighting feature ramps-down the courtesy lamps over 1.7 seconds when interior lighting deactivation is requested by any feature other than the panic alarm or battery saver. Dark Car The dark car configuration disables the activation of the illuminated entry and illuminated exit features when active. The courtesy lamps can still be activated by the instrument panel dimmer switch. Demand Lamps The demand lamps subsystem consists of the map/reading lamps, the glove compartment lamp (MKX) and the vanity mirror lamps located in the visors. The BCM energizes the battery saver relay to supply voltage to the demand lamps when the battery saver feature is not active. Ambient Lighting The ambient lighting subsystem provides illumination to the center console cupholders, the storage bin, the door map pockets, the door pull handles, the door release handles, and the front and rear footwells for illuminated entry or when the ignition is in run with the parking lamps on. The ambient lighting is controlled using the touch screen display in the center of the instrument panel. When the illuminated entry feature is active, the ambient lighting defaults to a pre-set color and brightness setting. When all the doors are closed and the illuminated entry is no longer active, the ambient lighting returns to the last color and brightness setting that was set by the operator. The touch screen display is used to select one of 7 color combinations or turn the ambient lighting feature on or off. The ambient lighting system retains the last color setting and brightness between uses. For vehicles with memory seats, the ambient lighting color can also be set to correspond to the Driver 1 or Driver 2 settings. Interior Lighting – Testing and Diagnostics (Introduction) Principles of Operation The Body Control Module (BCM) controls all the interior lighting functions and timing by monitoring inputs from the following: door ajar switches liftgate ajar switch (manual liftgate) Liftgate/Trunk Module (LTM) (power liftgate) ignition state Front Lighting Control Module (FLM) Remote Keyless Entry (RKE) system vehicle speed The BCM turns off the courtesy lamps when the vehicle speed exceeds 15 km/h (9 mph) or 5 km/h (3 mph) for the puddle lamps, unless the courtesy lamps are turned on using the instrument panel dimmer switch (integrated into the FLM ). Interior Lamp Arbitrator The interior lamp arbitrator (programming within the BCM ) chooses between the interior lighting delay, the illuminated entry and exit, the battery saver, and the alarm flash processing to determine which feature has precedence of activating and deactivating the interior lamps. Ambient Lighting The HVAC module controls the ambient lighting system. When requested, the HVAC module provides voltage and ground to the LEDs. There are 3 LEDs (Edge) (red, blue and green) or 4 LEDs (MKX) (red, blue, green and white) housed within each LED assembly. By illuminating various color combinations, the LEDs are able to produce 7 different colors of ambient light. The HVAC module receives input from the Accessory Protocol Interface Module (APIM) and the Body Control Module (BCM) over the communication network for color and brightness settings. The display interface in the center of the instrument panel is used to cycle through different color variations or turn the ambient lighting feature on or off. The APIM communicates messages over the High Speed Controller Area Network (HS-CAN) to the Body Control Module (BCM) . The BCM gateways the messages to the HVAC module over the Medium Speed Controller Area Network (MS-CAN) . The HVAC module retains the last color and brightness setting between uses. Field-Effect Transistor (FET) Protection A Field-Effect Transistor (FET) is a type of transistor that, when used with module software, monitors and controls current flow on module outputs. The FET protection strategy prevents module damage in the event of excessive current flow. The BCM utilizes an FET protective circuit strategy for many of its outputs (for example, a headlamp output circuit). Output loads (current level) are monitored for excessive current (typically short circuits) and are shut down (turns off the voltage or ground provided by the module) when a fault event is detected. A short circuit DTC is stored at the fault event and a cumulative counter is started. When the demand for the output is no longer present, the module resets the FET circuit protection to allow the circuit to function. The next time the driver requests a circuit to activate that has been shut down by a previous short (FET protection) and the circuit is still shorted, the FET protection shuts off the circuit again and the cumulative counter advances. When the excessive circuit load occurs often enough, the module shuts down the output until a repair procedure is carried out. Each FET protected circuit has 3 predefined levels of short circuit tolerance based on the harmful effect of each circuit fault on the FET and the ability of the FET to withstand it. A module lifetime level of fault events is established based upon the durability of the FET . If the total tolerance level is determined to be 600 fault events, the 3 predefined levels would be 200, 400 and 600 fault events. When each tolerance level is reached, the short circuit DTC that was stored on the first failure cannot be cleared by a command to clear the continuous DTCs. The module does not allow this code to be cleared or the circuit restored to normal operation until a successful self-test proves that the fault has been repaired. After the self-test has successfully completed (no on-demand DTCs present), DTC U1000:00 and the associated DTC (the DTC related to the shorted circuit) automatically clears and the circuit function returns. When each level is reached, the DTC associated with the short circuit sets along with DTC U1000:00. These DTCs are cleared using the module on-demand self-test, then the Clear DTC operation on the scan tool (if the on-demand test shows the fault corrected). The module never resets the fault event counter to zero and continues to advance the fault event counter as short circuit fault events occur. If the number of short circuit fault events reach the third level, then DTCs U1000:00 and U3000:49 set along with the associated short circuit DTC. DTC U3000:49 cannot be cleared and the module must be replaced after the repair. The BCM FET protected output circuits for the interior lighting system are the interior courtesy lamp and puddle lamp output circuits. Inspection and Verification Verify the customer concern. Visually inspect for obvious signs of electrical damage. Visual Inspection Chart Electrical Body Control Module (BCM) fuse(s): 4 (10A) (demand lamps) 12 (15A) (courtesy lamps) Wiring, terminals or connectors Bulb(s) Interior lamp(s) Puddle lamp(s) Scuff plate lamp(s) Cargo lamp Glove compartment lamp Vanity mirror lamp(s) Instrument panel dimmer switch (integrated into the Front Lighting Control Module (FLM) ) 2 Quote Link to comment Share on other sites More sharing options...
