SELAWD2011 Posted August 5, 2011 Report Share Posted August 5, 2011 Mine do the same thing. You can't really tell the difference on mine versus before. In the OE configuration, light was skewed to one side more. I can't really see the difference currently, so I don't mess with it any more. I'm sure there's a way to turn the bulbs... Just not sure it's quite worth the work. WOW!!! THANKS FOR THE PROMPT REPLY!!! I really appreciate it!!! Quote Link to comment Share on other sites More sharing options...
SELAWD2011 Posted August 5, 2011 Report Share Posted August 5, 2011 Also... did you push the LEDs in entirely... I was able to get all 6 leds to light up by only pushing them in only enough... however... Im wondering if it really is enough so that they dont pop out... Quote Link to comment Share on other sites More sharing options...
cal3thousand Posted August 5, 2011 Author Report Share Posted August 5, 2011 Also... did you push the LEDs in entirely... I was able to get all 6 leds to light up by only pushing them in only enough... however... Im wondering if it really is enough so that they dont pop out... I didn't push them in too much. IIRC, they wanted to sit even deeper in the groove, but I didn't feel that was going to make a good connection. If you shake the housing with your hand before popping them back into the car, you can assure yourself of the connection. Unless you're going offroading, if it survives the shake test, it should stay while driving. Quote Link to comment Share on other sites More sharing options...
cal3thousand Posted October 31, 2011 Author Report Share Posted October 31, 2011 Bump for updated coupon code for Halloween. Quote Link to comment Share on other sites More sharing options...
