Paquito_666 Posted May 27, 2011 Report Share Posted May 27, 2011 Hello: I have a 2010 Edge and I notice a red LED ligth stays on and illumiates the parking brake. I turned off all the ambient lights and all other lights are off, including the dash. Is this normal? Thanks- Quote Link to comment Share on other sites More sharing options...
cal3thousand Posted May 27, 2011 Report Share Posted May 27, 2011 Hello: I have a 2010 Edge and I notice a red LED ligth stays on and illumiates the parking brake. I turned off all the ambient lights and all other lights are off, including the dash. Is this normal? Thanks- If your parking brake is not set and the light remains lit, there is something wrong. Could be the sensor. You're still under warranty I presume, so I would advise you to take the car in for repair. Quote Link to comment Share on other sites More sharing options...
milktruk Posted May 27, 2011 Report Share Posted May 27, 2011 Are you saying the ambient just above the parking brake is not shutting off? Does it change colors as you change the ambient settings? Quote Link to comment Share on other sites More sharing options...
cal3thousand Posted May 27, 2011 Report Share Posted May 27, 2011 Are you saying the ambient just above the parking brake is not shutting off? Does it change colors as you change the ambient settings? Looks like I missed the question... Ambient light should only be on when your parking or headlights are on. And they should all go out together. Quote Link to comment Share on other sites More sharing options...
Paquito_666 Posted May 29, 2011 Author Report Share Posted May 29, 2011 Looks like I missed the question... Ambient light should only be on when your parking or headlights are on. And they should all go out together. Thanks. The light stays on and the it does not change when I press the ambient light button. I'll get it checked. Quote Link to comment Share on other sites More sharing options...
