sdsukid Posted May 25, 2011 Report Share Posted May 25, 2011 I used a 2 ohm equalizer and nothing changed. There are 3 wires to the bulb socket, an outside green inside green and outside purple. I'm assuming purple is ground. Any help on higher ohm or led bulb that needs no equalizer... thanks Quote Link to comment Share on other sites More sharing options...
cal3thousand Posted May 26, 2011 Report Share Posted May 26, 2011 (edited) I used a 2 ohm equalizer and nothing changed. There are 3 wires to the bulb socket, an outside green inside green and outside purple. I'm assuming purple is ground. Any help on higher ohm or led bulb that needs no equalizer... thanks You're putting the load in parallel to the circuit right? For LEDs that need no equalizer, check for "CANBUS LED" (not to be confused with cannibus ) or "No Error LED" EDIT: I just replied to that other thread you posted in: http://www.fordedgef...nction-box-sjb/ Edited May 26, 2011 by cal3thousand Quote Link to comment Share on other sites More sharing options...
