Jamie Stross Posted May 16, 2011 Report Share Posted May 16, 2011 Hey, I'm wondering how to take out the step/courtesy light under the mirror. im pretty sure i just broke mine trying to pry it out where that hole is, so i need help. how the hell do i take it out? its all loose now, and same thing with the map lights, how do you get that cover off, i got as far as the two visible clips by the sunglasses holder Quote Link to comment Share on other sites More sharing options...
Edge_Vision Posted June 2, 2011 Report Share Posted June 2, 2011 Hey, I'm wondering how to take out the step/courtesy light under the mirror. im pretty sure i just broke mine trying to pry it out where that hole is, so i need help. how the hell do i take it out? its all loose now, and same thing with the map lights, how do you get that cover off, i got as far as the two visible clips by the sunglasses holder puddle lamps ---> http://www.fordedgeforum.com/index.php?/topic/3372-led-puddle-lamps/ As for map lights, I just carefully pulled the cover off by working around it. Pulling little by little. Good luck. Quote Link to comment Share on other sites More sharing options...
akirby Posted June 2, 2011 Report Share Posted June 2, 2011 Why do they need to be removed? Quote Link to comment Share on other sites More sharing options...
