Brake light/ turn signals rear
tubby102
I had an intermittant turn signal, rear drivers side. I switched the lamp out with the opposite side and now I have no rear turn signals or brake lights ?
The brake switch is ok as the brake light on the tail gate works.
Lamps are all ok, they are on and I've checked them with a meter.
It's an '08 limited
Please help as the OPP are bound to pull me if I drive it !
It's an '08 limited
Can we have a little more info?
“Lamps are all ok, they are on and I've checked them with a meter.”
Lamps = tail lights?
“I've checked them with a meter.”
The brake/turn bulb?
Now a suggestion.
Rule # 1 “always test the tester” (not your meter)
Go buy new bulbs and install 1 in the passenger side only.
Check to see if it works.
Good luck
ab
Thanks for the info, you were right, test the tester.
Sometimes you can't see the wood for the trees.
2 new lamps are all is ok, dual filament lamps threw me !
Thanks again !
Now a suggestion.
Good luck
ab
  • 1 year later...
