railroad Posted May 7, 2011 Report Share Posted May 7, 2011 I have a 2010 and have no problems in the operation of the MKX. It does have a slow shift from 1st to 2nd gear from a stop. It shifts on time, but seems to reduce throttle go between gears engage second then add throttle back. That is probably the way Ford has it programed, but it sure feels primitive. The rest of the shifts feel normal. Is this normal for other owners? Quote Link to comment Share on other sites More sharing options...
cal3thousand Posted May 7, 2011 Report Share Posted May 7, 2011 On 5/7/2011 at 2:25 AM, railroad said: I have a 2010 and have no problems in the operation of the MKX. It does have a slow shift from 1st to 2nd gear from a stop. It shifts on time, but seems to reduce throttle go between gears engage second then add throttle back. That is probably the way Ford has it programed, but it sure feels primitive. The rest of the shifts feel normal. Is this normal for other owners? I've noticed that the transmission sometimes has a brainfart, but I'm not certain of what gears. Usually downshifting out of 6th to pass is a pain, as the tranny thinks before hitting the right gear. Quote Link to comment Share on other sites More sharing options...
jackdaniel Posted May 14, 2011 Report Share Posted May 14, 2011 On 5/7/2011 at 2:25 AM, railroad said: I have a 2010 and have no problems in the operation of the MKX. It does have a slow shift from 1st to 2nd gear from a stop. It shifts on time, but seems to reduce throttle go between gears engage second then add throttle back. That is probably the way Ford has it programed, but it sure feels primitive. The rest of the shifts feel normal. Is this normal for other owners? My 2010 is like that also,very sluggish on 1st to 2nd shift. Quote Link to comment Share on other sites More sharing options...
mcali6301 Posted September 4, 2014 Report Share Posted September 4, 2014 I'm just seeing this post and it sounds like the same issue I have been having along with the occasional slip and thump when in traffic and minor acceleration sluggishness.. Already had it in the dealer and they applied TSB 11-12-13, I think it was...The work replaced the valve body gasket and removed a check ball. This seemed to have fixed the accel issues and slip and thump issue. I am however still noticing the gear shifting hesitations sometimes from 1-2 but mostly from 2-3....This happens only sometimes and I cannot pinpoint any particular reason or environment. Sometimes it shifts perfect other times it seems to have the "brainfart" as said before..... I find it hard to believe that the transmission can make these mistakes this many times and I'm beginning to think there is some issue with the PCM.. Quote Link to comment Share on other sites More sharing options...
FordService Posted September 30, 2014 Report Share Posted September 30, 2014 On 9/4/2014 at 3:55 PM, mcali6301 said: I'm just seeing this post and it sounds like the same issue I have been having along with the occasional slip and thump when in traffic and minor acceleration sluggishness.. Already had it in the dealer and they applied TSB 11-12-13, I think it was...The work replaced the valve body gasket and removed a check ball. This seemed to have fixed the accel issues and slip and thump issue. I am however still noticing the gear shifting hesitations sometimes from 1-2 but mostly from 2-3....This happens only sometimes and I cannot pinpoint any particular reason or environment. Sometimes it shifts perfect other times it seems to have the "brainfart" as said before..... I find it hard to believe that the transmission can make these mistakes this many times and I'm beginning to think there is some issue with the PCM.. Hi mcali6301, I've been going through these threads with a fine-toothed comb and just saw this post. Are you still experiencing this concern? Todd Quote Link to comment Share on other sites More sharing options...
mcali6301 Posted October 7, 2014 Report Share Posted October 7, 2014 yes I am still experiencing this concern. I had the car in for a transmission valve body upgrade which fixed the acceleration and tranny slip issue. I though it would fix the shifting issue also. Now I am starting to think it is NOT the tranny. SOMETIMES, the the car just loses power between shifts, it hesitates between shifts and I am starting to think it might have something to do with the throttle body.. I will bring it up when I take it in for routine maintenance but I post here to see if anyone else experiences the same.. Quote Link to comment Share on other sites More sharing options...
mcali6301 Posted October 7, 2014 Report Share Posted October 7, 2014 Also thinking it may be a TPS issue HOWEVER, the hesitation in shifting is 100% all of the time. Sometimes I have good drives with perfect shifting, other times not. Quote Link to comment Share on other sites More sharing options...
