This was not installed in my edge.. is this something you can add afterwards?.. .. Adaptave Cruise i think ... something that can be programmed?
if this is in the wrong section, please move!.. thanks....
Thanks in advance!
Anything's possible, but it won't be easy. There's the sensor and bracket that mount out front (probably $1000+ from the dealer) then you've got to wire it, get the steering wheel controls, get the HUD (probably requires a whole new instrument panel), then reprogram the cluster and the PCM. Not sure but you may even need to change the fascia since the part that's in front of the sensor is critical to proper operation.
Edited by Waldo
ewwww... to much work! lol......
