Walk-n-Edge Posted April 23, 2011 Report Share Posted April 23, 2011 My battery on my 2007 Ford Edge SEL recently went dead. I put in a brand new battery and nothing. Can't even get the radio to turn on. I'm absolutely positive I hooked the battery up right. Put everything back together right but still no juice. I'm stumped, there is a little corrosion on the terminals. But not enough to prevent an electrical connection. Only thing I can think of. I didn't put these two square mat looking things up inder the terminals when I reinstalled them. Can't see how they would have any bearing on anything anyway. Any help would be greatly appreciated. Thanks in advance. Walk Quote Link to comment Share on other sites More sharing options...
akirby Posted April 23, 2011 Report Share Posted April 23, 2011 My battery on my 2007 Ford Edge SEL recently went dead. I put in a brand new battery and nothing. Can't even get the radio to turn on. I'm absolutely positive I hooked the battery up right. Put everything back together right but still no juice. I'm stumped, there is a little corrosion on the terminals. But not enough to prevent an electrical connection. Only thing I can think of. I didn't put these two square mat looking things up inder the terminals when I reinstalled them. Can't see how they would have any bearing on anything anyway. Any help would be greatly appreciated. Thanks in advance. Walk Where did you get the battery? Perhaps it wasn't charged. Did you try jumping it? Quote Link to comment Share on other sites More sharing options...
Walk-n-Edge Posted April 23, 2011 Author Report Share Posted April 23, 2011 Where did you get the battery? Perhaps it wasn't charged. Did you try jumping it? Brand new battery from Autozone. Quote Link to comment Share on other sites More sharing options...
akirby Posted April 23, 2011 Report Share Posted April 23, 2011 Brand new battery from Autozone. Should have let them install it for you. Clean the terminals and check all of the fuses under the dash and under the hood. If you can jump it take it back and let them test it to be safe. Quote Link to comment Share on other sites More sharing options...
Walk-n-Edge Posted April 23, 2011 Author Report Share Posted April 23, 2011 Should have let them install it for you. Clean the terminals and check all of the fuses under the dash and under the hood. If you can jump it take it back and let them test it to be safe. Kinda hard to do that when you can't crank the car. Then drive it to Autozone. Quote Link to comment Share on other sites More sharing options...
Theakerr Posted April 23, 2011 Report Share Posted April 23, 2011 Do you mean it wont even start if a you use a set of jump/booster cables?. Does it crank over with the cables? If it wont crank or start with a boost you may have damaged some of the electronics when you put in the new battery. Quote Link to comment Share on other sites More sharing options...
akirby Posted April 23, 2011 Report Share Posted April 23, 2011 Kinda hard to do that when you can't crank the car. Then drive it to Autozone. Ever hear of jumper cables/jumpstart box? For $75 you can keep one in the garage charged and ready to jump your car. If you suspect your battery may be dying throw it in the car and you can jump yourself off anytime. Or anyone else. Very handy. Quote Link to comment Share on other sites More sharing options...
Walk-n-Edge Posted April 23, 2011 Author Report Share Posted April 23, 2011 Ever hear of jumper cables/jumpstart box? For $75 you can keep one in the garage charged and ready to jump your car. If you suspect your battery may be dying throw it in the car and you can jump yourself off anytime. Or anyone else. Very handy. Obviously power isn't the problem. So even if I had a jump box. It would do me no good. Because it would just provide the same voltage the new battery is providing. For anyone who can actually help me. Last thing I have done is take come coke and a brillo pad. Cleaned what little corrosion I had on my terminals off. Would this be covered under the powertrain warranty? Anyone? Tomorrow Im going go get a fluke and check all the fuses, the continuity across the fuseable link in the front and the continuity from positive to negative cable terminals. After that, I'm throwing in the towel. Quote Link to comment Share on other sites More sharing options...
carbonedge+ Posted April 24, 2011 Report Share Posted April 24, 2011 (edited) Last thing I have done is take come coke and a brillo pad. Cleaned what little corrosion I had on my terminals off. . What a waste of coke...should have used baking soda...or pepsi.... Edited April 24, 2011 by carbonedge+ Quote Link to comment Share on other sites More sharing options...
carbonedge+ Posted April 24, 2011 Report Share Posted April 24, 2011 On a more helpful note, my '07 stranded me once and wouldn't take a jump either. After installing a new battery though, it fired right up... Quote Link to comment Share on other sites More sharing options...
KonaBlueSport Posted April 24, 2011 Report Share Posted April 24, 2011 As others have stated are you sure the new battery is charged?? Being new doesnt guarantee its at a full charge. It may be defective from the factory or sat for a while and be low on charge. Did you try to jump the car b4 buying new battery? If so mioght it have been jumped backwards? Check fuses/fusable links/relays to see if the main fuse/relay is burned out... Quote Link to comment Share on other sites More sharing options...
akirby Posted April 24, 2011 Report Share Posted April 24, 2011 Obviously power isn't the problem. No, it's not obvious until you rule that out by testing it. Quote Link to comment Share on other sites More sharing options...
Walk-n-Edge Posted April 24, 2011 Author Report Share Posted April 24, 2011 No, it's not obvious until you rule that out by testing it. Tested it, and as I stated before. My 12 volts isn't the issue. The 12 volts is there. Quote Link to comment Share on other sites More sharing options...
