Winter is over - 22" wheels back on
REDSPORT
winter is over and I put my 22" rims back on my Edge Sport. I purchased the learning tool/fob last fall from the dealer. I downloaded the instructions on putting the edge in learning mode, went through the process and used the tool on each wheel, honk at each wheel and done. It took all of 5 mins. TPMS system is running.
I put on 18" lincoln rims for the winter with TPMS sensors so the system was working in the winter. This was my first time to program the system. This turned out better than i thought. I also learned that you can rotate the tires and the TPMS will not give you an error message.
