New Update April 11 2011
Garemz
So I went to the dealer today to get my winter tires switched over to my summer tires, they told me there was a dealer install update for my 2011 ford edge limited, so I told them to go ahead with it. 6 Hours and 5 tries later the update was installed successfully.
The only thing I see that's fixed is the ambient lighting works perfectly now, blue is blue and green is green.
Does anyone else notice what this update fixed?
icon_checkbox.png SYNC Version
Gen2 - V2.7 icon_checkbox.png BT4T-14D546-AL
icon_checkbox.png BT4T-14D546-DA
icon_checkbox.png BT4T-14D546-FA
icon_checkbox.png BT4T-14F496-AN
icon_checkbox.png BT4T-14F497-AL
icon_checkbox.png BT4T-14F603-AL
Here is what is supposed to have fixed and what the next one is to address:
Corrective actions released on 2/25/2011 with 11038 (BH - CIP):
· Microsoft OS level fix implemented to address black screens (still validating effectiveness)
· TravelLink Excessive Download Time (makes TravelLink appear inoperative)
· Sirius Channel Art Logo Mismatch due to database corruption over cold boot cycles
· USB detection robustness actions implemented
· Clock Inaccuracies
· Corrective actions for SYNC Services Voice Recognition Not Working
General
· Improved shortcut functionality
· Improved installer functionality
· Improved messaging for image upload
· Improved compatibility with USB broadband modems
Voice
· Improved climate Voice commands
· Corrected voice grammar rebuild on language switch
· Disabled "Nearest POI category" voice command when SD card removed
· Corrected issue when dialing POI phone number when no phone is connected
· Added "Services" command as semi-global command
Navigation/Travel Link
· Improved weather map UI
· Improved Navigation keyboard responsiveness
· Corrected POI selection errors in rare scenarios
· Corrected traffic info pop-up causing the user to get stuck in four corners in rare scenarios
· Corrected 5 day forecast highlighted option
Media
· Improved USB MSC/MTP device detection, indexing time, and playback
· Removed Bluetooth time counter and track number info for devices which do not support these functions
· Improved iPod Video Playback
· Improved A/V In Detection
· Improved Gracenote album art coverage, including genre images
· Corrected blank preset issue when switching from FM to Sirius in rare scenarios
· Corrected paused audio when transitioning from HD2 to non-HD station
Phone
· Improved Bluetooth phone stack recovery method
· Improved phone call echo cancellation
Services
· Optimized outgoing audio volume for Services features
· Corrected E911 pop-up hidden behind other menus in rare scenarios
However, please note that there is a new release due out in “April” to fix the following conditions.
Corrective actions planned for April software release
· Blank/Black display screen
· AM/FM missing preset Display Information
· Momentary Display Freeze
· Improvements to ensure radio maintains previous state (e.g. Audio Off) after phone call or voice command. (Only present with BH – CIP level software)
I have 2.7 (installed a few weeks ago)
I noticed SyncMyRide tells me there is an update available..
There are important updates for your vehicle. Please click Get Updates.
But nothing is there except the status update checker.
That's weird... maybe it's getting ready for a transition?
EDIT: checked and its the same for me... going to install the status checker on a USB drive once I get this computer to shutdown properly. banghead.gif
Edited by cal3thousand
I get the same when I check SyncMyRide and I'm on v2.4. Doesn't even say the new update is dealer install only.
I think this is showing up for everybody. On the Owner to Owner site it was reported to be a result of the Sync site upgrade over the weekend.
Still doesn't show I need any update. Still on 1.8.
Amazing that you are running 1.8!
I was reading the sync forums and there are threads there discussing the need to unplug USB drives before turning off the car and/or starting it.
I leave my iPod plugged in all the time. I was wondering if you leave anything plugged into your USB port.
Could this be why some folks have problems and others don't?
I have a 16 GB kingston USB key with 10 GB of music plugged in all the time, and a BB Curve 9300 running OS 5(yes phone calls, and contact pictures, and the occasional BT audio streaming works Haven't tried text messaging, but it shows up, I never text message, but I guess I should try.. sync 1.8 with about 3 auto reboots and 2 fuse pulls in over 6 months...
Sync is a bit laggy(white screen if you open and close the drivers door after shutting down etc), but eventually I should take it in and get an upgrade. I'm in canada so none of the travel link stuff is available or loaded it seems, so maybe my system has a bit more breathing room? uses less memory and seems to work longer without reboots?
M.
I have a 32g ipod touch plugged in almost permanently (took it out for vacation) my iphone works for streaming and talking (all I care about). One reboot, no fuse pulls since September.
Just rolled over 7k miles, so almost time for an oil change - might do an update then.
