liamoc Posted April 11, 2011 Report Share Posted April 11, 2011 Hi there, This is directed at anyone who has done the Retro Solution HID kit upgrade. I read somewhere on here an alteration is needed to the headlight dust covers? Can anyone verify/confirm this? Just want to know what I'm getting into be before placing the order. I have a 2007 Edge if that helps. Quote Link to comment Share on other sites More sharing options...
toakley1 Posted April 11, 2011 Report Share Posted April 11, 2011 Hi there, This is directed at anyone who has done the Retro Solution HID kit upgrade. I read somewhere on here an alteration is needed to the headlight dust covers? Can anyone verify/confirm this? Just want to know what I'm getting into be before placing the order. I have a 2007 Edge if that helps. I have a 2011 Edge, so this is based on that model. The dust cover will need a 1" hole drilled through the center. A regular 1" spade type drill bit will work just fine. The light kit comes with a grommet that will fit the 1" hole in the cover. All necessary wiring passes through that grommet to connect the factory wiring and the HID wiring. It all worked out fine on mine. No other modifications were needed. Quote Link to comment Share on other sites More sharing options...
