yogregb Posted April 6, 2011 Report Share Posted April 6, 2011 Going in sat, they probably order parts...also getting my complementry oil change....I'll let you guys know.... Quote Link to comment Share on other sites More sharing options...
yogregb Posted April 10, 2011 Author Report Share Posted April 10, 2011 Got my first free oil change.... I will be doing my own from here on out............................ I hate dealers Anyways, the reason I,m updating this thread is, I dis-connected the battery to re boot everything and guess what?? Nav works again! Plan on doing my own updates from now on as well...:happy feet: Quote Link to comment Share on other sites More sharing options...
sboots88 Posted April 11, 2011 Report Share Posted April 11, 2011 Got my first free oil change.... I will be doing my own from here on out............................ I hate dealers Anyways, the reason I,m updating this thread is, I dis-connected the battery to re boot everything and guess what?? Nav works again! Plan on doing my own updates from now on as well...:happy feet: Rather than disconnect the battery, you can pull fuse 29 on the 2011 Edge to do the same thing. Although the fuse panel is in a terrible location, it beats pulling the battery cable. You can't do the major updates yourself as they are only made available through the dealers. Minor updates are made available at the official Sync web site and can be applied with a USB flash drive. -steve Quote Link to comment Share on other sites More sharing options...
cal3thousand Posted April 11, 2011 Report Share Posted April 11, 2011 Rather than disconnect the battery, you can pull fuse 29 on the 2011 Edge to do the same thing. Although the fuse panel is in a terrible location, it beats pulling the battery cable. You can't do the major updates yourself as they are only made available through the dealers. Minor updates are made available at the official Sync web site and can be applied with a USB flash drive. -steve You can't do major updates yourself "right now" Once If someone smart enough and with enough access gets their hands on it.... Quote Link to comment Share on other sites More sharing options...
