Lennyt Posted March 29, 2011 Report Share Posted March 29, 2011 How does one remove the radio trim bezel? I want to replace a OEM radio with a navigation unit and not mess up the trim, where are the attach clips or screws? Thanks in advance. Quote Link to comment Share on other sites More sharing options...
07CRUSH Posted March 29, 2011 Report Share Posted March 29, 2011 On 3/29/2011 at 11:40 AM, Lennyt said: How does one remove the radio trim bezel? I want to replace a OEM radio with a navigation unit and not mess up the trim, where are the attach clips or screws? Thanks in advance. Just clips, give it a tug from the top and it should pop off Quote Link to comment Share on other sites More sharing options...
CardinalSpear Posted March 30, 2011 Report Share Posted March 30, 2011 I always remove it by pulling from the bottom of the the whole trim piece ( right above the lil cubby storage space) and gently pull. You can also do it the way mentioned above. I just replaced the stock 6 disc player for a full touch screen unit from pioneer along with the parking break bypass for watching dvds.. Quote Link to comment Share on other sites More sharing options...
spongers Posted March 30, 2011 Report Share Posted March 30, 2011 On 3/30/2011 at 5:45 AM, CardinalSpear said: I always remove it by pulling from the bottom of the the whole trim piece ( right above the lil cubby storage space) and gently pull. You can also do it the way mentioned above. I just replaced the stock 6 disc player for a full touch screen unit from pioneer along with the parking break bypass for watching dvds.. Is this for the 2011 model? Quote Link to comment Share on other sites More sharing options...
hunter306 Posted May 6, 2011 Report Share Posted May 6, 2011 On 3/30/2011 at 5:45 AM, CardinalSpear said: I always remove it by pulling from the bottom of the the whole trim piece ( right above the lil cubby storage space) and gently pull. You can also do it the way mentioned above. I just replaced the stock 6 disc player for a full touch screen unit from pioneer along with the parking break bypass for watching dvds.. Cardinal, Any pictures of your Pioneer installation? Quote Link to comment Share on other sites More sharing options...
Lennyt Posted May 20, 2011 Author Report Share Posted May 20, 2011 Thanks for the advice, this is what I ended up putting in. Awesome plug & play unit. http://www.jewellet.com/Ford-Edge-DVD-Player/Ford-Edge-Navigation-System Quote Link to comment Share on other sites More sharing options...
ThinLine Posted May 21, 2011 Report Share Posted May 21, 2011 On 5/20/2011 at 8:20 PM, Lennyt said: Thanks for the advice, this is what I ended up putting in. Awesome plug & play unit. http://www.jewellet.com/Ford-Edge-DVD-Player/Ford-Edge-Navigation-System This system is not compatible with sync...?...!! Sync is the main reason the wife wanted this CUV. Is there a way to maintain sync with the installation of this unit ? Quote Link to comment Share on other sites More sharing options...
Lennyt Posted May 21, 2011 Author Report Share Posted May 21, 2011 On 5/21/2011 at 6:06 PM, ThinLine said: This system is not compatible with sync...?...!! Sync is the main reason the wife wanted this CUV. Is there a way to maintain sync with the installation of this unit ? You can ask the folks at jewellet.com, I really don't know. Quote Link to comment Share on other sites More sharing options...
