Source for Switched 12V
I am installing an add-on Sirius Radio to my 2011 Edge SE. I need a source of 12V that is switched with the ignition (or accessories). Does anyone know a source for switched voltage in the Edge? Most of the switched voltage is only 2.4V.
Where are you measuring the voltage and how? It should all be 12V from the fuse box. Get a fuse tap and find a fuse to replace that's switched. Either you're measuring it wrong or there's something wrong with your voltmeter.
I have measured the voltage at the fuse block and at several points on various wires. I believe the 2.4V is correct. I think these lines have something to do with the CAN-Bus System.
I am hoping someone can point me to a specific location (fuse, wire, etc.) to tap into. I have already checked a bunch of locations. I would prefer not guessing anymore.
  • 2 months later...
Fuse #35
  • 9 months later...
