luscombedude Posted March 25, 2011 Report Share Posted March 25, 2011 I have a 2008 Ford edege AWD and the cooling fan stopped working, does the block it plugs into control the electricity going to the fan or is there another source to tell the fan to operate. I am hoping the fan motor went bad, but would like to hear if anyone else has had this problem and the best way to fix it. Thanks for your help. Quote Link to comment Share on other sites More sharing options...
luscombedude Posted July 22, 2011 Author Report Share Posted July 22, 2011 I have a 2008 Ford edege AWD and the cooling fan stopped working, does the block it plugs into control the electricity going to the fan or is there another source to tell the fan to operate. I am hoping the fan motor went bad, but would like to hear if anyone else has had this problem and the best way to fix it. Thanks for your help. Update, I replaced the relay on the fan assembly. The relay cost well over $300.00 from ford, it didn't work. I finally found a complete replacement fan assembly fro Autozone that included the relay for under $280.00 and it went in in 15 minutes with very few tools. It worked great and the assembly has a lifetime gaurantee. Good luck on yours. Quote Link to comment Share on other sites More sharing options...
