TEXANOW Posted March 23, 2011 Report Share Posted March 23, 2011 NEED TO REPLACE THE OUTSIDE DOOR HANDLE ON THE RT REAR DOOR 2010 EDGE. LOOKS LIKE THE WINDOW, LATCH, ETC. ALL COME OUT TOGETHER ON THE PANEL UNDER THE INTERIOR TRIM PANEL, BUT NOT SURE. ANY HELP ANYONE! Quote Link to comment Share on other sites More sharing options...
JOEHIO Posted March 24, 2011 Report Share Posted March 24, 2011 If a problem with this, shouldn't it be covered under 3/36 bumper to bumper warranty ? Quote Link to comment Share on other sites More sharing options...
07CRUSH Posted March 24, 2011 Report Share Posted March 24, 2011 (edited) NEED TO REPLACE THE OUTSIDE DOOR HANDLE ON THE RT REAR DOOR 2010 EDGE. LOOKS LIKE THE WINDOW, LATCH, ETC. ALL COME OUT TOGETHER ON THE PANEL UNDER THE INTERIOR TRIM PANEL, BUT NOT SURE. ANY HELP ANYONE! There is a rubber plug on the door at the same height as the door handle(above the door latch) , pop the plug off and insert a Torx-20 and unscrew it 4-6 turns and check to see if the small piecs of the door handle moves ( if you pull on the handle the cover should be loose and should come off)slide the handle back and will slide out. Edited March 24, 2011 by 07CRUSH Quote Link to comment Share on other sites More sharing options...
mlfordedge Posted December 28, 2012 Report Share Posted December 28, 2012 Doh!!! I took off my driver's side door handle backing into a brick mailbox. Any advice on how to replace it? I ordered a new one already... Quote Link to comment Share on other sites More sharing options...
