trockli Posted March 19, 2011 Report Share Posted March 19, 2011 The iPhone is working as a phone with Sync using Bluetooth. However, Sync can't play any music when plugging the iPhone into the USB cable. I'm assuming that I can play music only through USB, not Bluetooth? Are there any known issues/tricks? Quote Link to comment Share on other sites More sharing options...
akirby Posted March 19, 2011 Report Share Posted March 19, 2011 The iPhone is working as a phone with Sync using Bluetooth. However, Sync can't play any music when plugging the iPhone into the USB cable. I'm assuming that I can play music only through USB, not Bluetooth? Are there any known issues/tricks? You can stream music from the iphone via bluetooth. If it doesn't work when plugged in then either it's not indexed yet or there's a problem with the metadata. Quote Link to comment Share on other sites More sharing options...
alias1 Posted March 20, 2011 Report Share Posted March 20, 2011 The iPhone is working as a phone with Sync using Bluetooth. However, Sync can't play any music when plugging the iPhone into the USB cable. I'm assuming that I can play music only through USB, not Bluetooth? Are there any known issues/tricks? If you check www.syncmyride.com is says that there are posible issues not using the original cable that came with the device or an "approved" usb cable (whatever that means...i think Ford had forgotten what USB stands for) Check your usb cable maybe?! Quote Link to comment Share on other sites More sharing options...
trockli Posted March 20, 2011 Author Report Share Posted March 20, 2011 You can stream music from the iphone via bluetooth. If it doesn't work when plugged in then either it's not indexed yet or there's a problem with the metadata. How do I i"index"? Quote Link to comment Share on other sites More sharing options...
wilsons66604 Posted March 20, 2011 Report Share Posted March 20, 2011 If you check www.syncmyride.com is says that there are posible issues not using the original cable that came with the device or an "approved" usb cable (whatever that means...i think Ford had forgotten what USB stands for) Check your usb cable maybe?! The iPhone plays over blue tooth and USB. Media plays with no problem on my edge, even if not indexed. I have had cheap cables that were only for charging and media would not play so use an original grade cable. Upgrading iPhone iOS is always good too Quote Link to comment Share on other sites More sharing options...
