twinkiesd Posted March 16, 2011 Report Share Posted March 16, 2011 I just purchased in November a 2007 Ford Edge SEL AWD. It came off of lease so it only had one owner prior to myself. I had an issue right from the start with the burning smell from the PTU leaks and had that fixed under power train warranty. I've also noticed this strange random vibration. At first I didn't think anything of it, until I realized it was happening "regularly." The best way to describe it is a mild vibration for 20-30 seconds and then it stops. It kind of feels like when you go over rumble strips on the side of the highways, those vibrations that wake people up that start to drift off. It doesn't seem to be at a specific time - going up a hill versus flat, a certain speed, or turning... It does always happen while driving, not idling, but that's the only thing I can pin down. Does anyone know what it might be?? After the PTU issue, I'm starting to worry that this car is a dud.... Please help... Quote Link to comment Share on other sites More sharing options...
curio Posted March 23, 2011 Report Share Posted March 23, 2011 Have you tried getting your wheels rebalanced? If a regular balancing doesn't work, try finding a shop that will do what's called a 'road force balance'. Just narrow this down one thing at a time, and start with balancing. Quote Link to comment Share on other sites More sharing options...
tldt2003 Posted October 9, 2011 Report Share Posted October 9, 2011 I just purchased in November a 2007 Ford Edge SEL AWD. It came off of lease so it only had one owner prior to myself. I had an issue right from the start with the burning smell from the PTU leaks and had that fixed under power train warranty. I've also noticed this strange random vibration. At first I didn't think anything of it, until I realized it was happening "regularly." The best way to describe it is a mild vibration for 20-30 seconds and then it stops. It kind of feels like when you go over rumble strips on the side of the highways, those vibrations that wake people up that start to drift off. It doesn't seem to be at a specific time - going up a hill versus flat, a certain speed, or turning... It does always happen while driving, not idling, but that's the only thing I can pin down. Does anyone know what it might be?? After the PTU issue, I'm starting to worry that this car is a dud.... Please help... Did you ever get any resolution on this? I have a vibration at times in the middle of the car.... can feel it through the console. Seems to be throttle induced. Quote Link to comment Share on other sites More sharing options...
EdgeOwner11 Posted October 11, 2011 Report Share Posted October 11, 2011 Does anyone have a 2011 Edge with a rattle in the dash? I have a rattle that goes away if I press on the vertical trim piece that runs from the top of the dash down to the center counsel (see red arrow on the attached photo). Just looking for a fix. Thanks.2011Edge.bmp Quote Link to comment Share on other sites More sharing options...
