On screen short-cuts
Two weeks ago I had no problem setting up a screen shortcut in the Climate quadrant for easy access to my seat warmers. Now, since the weather is getting warmer, I'd like to change the "shortcut" to something else. For the life of me, I can't remember where the shortcut can be programmed. I feel like I've looked everywhere for it.
Anyone know offhand?
Touch manual says:
Press Home again and a pop-up will appear with three graphics.
1. Select (1) for your display to be your chosen wallpaper (if saved).
2. Select (2) for the full corners display with preselected shortcuts.
3. Select (3) to customize your home screen by setting up your own
shortcuts.
When on the shortcut screen, select
‘Edit/Add shortcuts’ and the system
will walk you through the process of
setting and saving your shortcuts
