thinguy Posted March 8, 2011 Report Share Posted March 8, 2011 I've not got an Edge yet, I'm still looking for the best model/deal but it will be an SEL so no HD Radio but will have MFT/Sync. Thinking that rather than connecting my iphone every time I get in the car, or running the battery draining bluetooth I may want to just use a usb drive or SD card for music. I don't buy a lot of new music so my collection would be fairly static. Is MP3 the only format supported? Any limitation to bitrate, etc? Any limitation to format or size of usb or sd card? Thanks all. Quote Link to comment Share on other sites More sharing options...
akirby Posted March 8, 2011 Report Share Posted March 8, 2011 I've not got an Edge yet, I'm still looking for the best model/deal but it will be an SEL so no HD Radio but will have MFT/Sync. Thinking that rather than connecting my iphone every time I get in the car, or running the battery draining bluetooth I may want to just use a usb drive or SD card for music. I don't buy a lot of new music so my collection would be fairly static. Is MP3 the only format supported? Any limitation to bitrate, etc? Any limitation to format or size of usb or sd card? Thanks all. www.syncmyride.com www.motorcraftservice.com -> owner guides you can get both the owner's manual and the MFT/sync supplements online. Enjoy! Quote Link to comment Share on other sites More sharing options...
sabasigh Posted March 18, 2011 Report Share Posted March 18, 2011 I've not got an Edge yet, I'm still looking for the best model/deal but it will be an SEL so no HD Radio but will have MFT/Sync. Thinking that rather than connecting my iphone every time I get in the car, or running the battery draining bluetooth I may want to just use a usb drive or SD card for music. I don't buy a lot of new music so my collection would be fairly static. Is MP3 the only format supported? Any limitation to bitrate, etc? Any limitation to format or size of usb or sd card? Thanks all. I'm using a 32gb SD card...about half full but contains all my music. Works great. Quote Link to comment Share on other sites More sharing options...
jackson5 Posted May 31, 2011 Report Share Posted May 31, 2011 Instead of making a new thread I'll just add to this one. I have a SD card issue. I inserted my SD card. Then i switched to other music sources. But every time I turn on the car again it always goes to the SD card and starts playing, instead of using the last source i was using. Any way to change this? I had to take my SD card out.. Quote Link to comment Share on other sites More sharing options...
jackson5 Posted May 31, 2011 Report Share Posted May 31, 2011 Instead of making a new thread I'll just add to this one. I have a SD card issue. I inserted my SD card. Then i switched to other music sources. But every time I turn on the car again it always goes to the SD card and starts playing, instead of using the last source i was using. Any way to change this? I had to take my SD card out.. I think I found the answer, so posting for other people: Media Player Settings: Select to access: • Autoplay on/off: With this feature on, the system will automatically switch to the media source upon intial connection and you can listen to music which has already been randomly indexed during the indexing process. With this feature off, the system will not automatically switch to the inserted media source. Quote Link to comment Share on other sites More sharing options...
cal3thousand Posted May 31, 2011 Report Share Posted May 31, 2011 Instead of making a new thread I'll just add to this one. I have a SD card issue. I inserted my SD card. Then i switched to other music sources. But every time I turn on the car again it always goes to the SD card and starts playing, instead of using the last source i was using. Any way to change this? I had to take my SD card out.. I think v2.8 of Sync addressed this issue. Don't quote me on it though. Quote Link to comment Share on other sites More sharing options...
mcali6301 Posted July 18, 2014 Report Share Posted July 18, 2014 Do you get the same features such as gracenote and album artwork using the SD card for music Versus a USB device? Quote Link to comment Share on other sites More sharing options...
akirby Posted July 18, 2014 Report Share Posted July 18, 2014 I believe so. They're just mp3 files stored externally either way. Quote Link to comment Share on other sites More sharing options...
FordIVTteam Posted July 18, 2014 Report Share Posted July 18, 2014 You sure do Do you get the same features such as gracenote and album artwork using the SD card for music Versus a USB device? I believe so. They're just mp3 files stored externally either way. You sure do! Just make sure that the files are in one of our supported formats: MP3, WMA, WAV, or AAC.Rebecca Quote Link to comment Share on other sites More sharing options...
mcali6301 Posted July 18, 2014 Report Share Posted July 18, 2014 Thanks! Another question, Whats the best way to get the music onto the flash drive, drag and drop through explorer or is there a good way to import from itunes onto the flash drive?? The MP3 filenames are a little jacked up and they are much better organized in itunes.... Quote Link to comment Share on other sites More sharing options...
akirby Posted July 19, 2014 Report Share Posted July 19, 2014 There is a free program called itunes export that works great. Quote Link to comment Share on other sites More sharing options...
egar Posted July 19, 2014 Report Share Posted July 19, 2014 I just drag and drop from the iTunes app to my SD card. You can also copy directly the audio files directly from the iTunes folder to SD card or USB. Copying folder structure and all works just fine. Quote Link to comment Share on other sites More sharing options...
mcali6301 Posted July 21, 2014 Report Share Posted July 21, 2014 I just copied the the folder/file structure and it's working great! 1 Quote Link to comment Share on other sites More sharing options...
akirby Posted July 21, 2014 Report Share Posted July 21, 2014 Note that this only works for non-DRM protected music files. Quote Link to comment Share on other sites More sharing options...
