DIY Oil Change on '11 AWD Edge
tmuenster
Oil Change Degree of Difficulty
11 members have voted
  1. 1. Is it easy to change the oil in an AWD Edge?
I am considering the purchase of a 2011 Edge LTD in AWD. Does anyone with the AWD model change their own oil? I had a 2005 Ford F-150 where the oil filter was located in a terrible place. I cursed everytime I changed the oil. Is it easy to change the oil on the Edge?
Thanks,
Tom
  • 5 weeks later...
Yes, the filter is at the lower front of the engine and has easy access. Drain plug on pan is easy too. Get the front up a bit on some ramps and it is very easy vehicle to change oil on. Wal-mart sells the Motorcraft 5W-20 semi-synthetic oil cheap. It is in 5 qt jugs and you need about 5.5 qts with a filter change. WM also sells the Motorcraft filters for good price.
