Circle3 Posted March 4, 2011 Report Share Posted March 4, 2011 New owner of 2011 Edge Limited. On the learning curve. Night time driving I see there is ambient lighting of the driver and passenger floor areas (blue). The Panel Dimmer Control does not dim these floor lights. At the moment I am not use to floor lighting driving at night. Is there a way to turn these floor lights off? Thanks, Sean Quote Link to comment Share on other sites More sharing options...
akirby Posted March 4, 2011 Report Share Posted March 4, 2011 New owner of 2011 Edge Limited. On the learning curve. Night time driving I see there is ambient lighting of the driver and passenger floor areas (blue). The Panel Dimmer Control does not dim these floor lights. At the moment I am not use to floor lighting driving at night. Is there a way to turn these floor lights off? Thanks, Sean I don't know Sean but I'm virtually certain that it's explained in the owner's manual. You can get them online here (and use the search feature if necessary): http://www.motorcraftservice.com -> owner guides Quote Link to comment Share on other sites More sharing options...
Edgieguy Posted March 4, 2011 Report Share Posted March 4, 2011 MFT center stack. Hit menu and then vehicle settings and then ambient lighting. There is a slide that you move with your finger to adjust the brightness, 0-100% Quote Link to comment Share on other sites More sharing options...
Circle3 Posted March 4, 2011 Author Report Share Posted March 4, 2011 I don't know Sean but I'm virtually certain that it's explained in the owner's manual. You can get them online here (and use the search feature if necessary): http://www.motorcraftservice.com -> owner guides I looked in the owner's manual and found no discussion of floor lights (p72-p75). Quote Link to comment Share on other sites More sharing options...
Circle3 Posted March 4, 2011 Author Report Share Posted March 4, 2011 MFT center stack. Hit menu and then vehicle settings and then ambient lighting. There is a slide that you move with your finger to adjust the brightness, 0-100% Not only could I change the floor brightness but I had an on/off icon. Could turn lighting off. Nice. Thank you. Quote Link to comment Share on other sites More sharing options...
