Blinker Volume
SweetCandyEdge
I've had my 2011 Edge for 3 days now and I find the blinker volume to be very low. In my previous vehicle this was adjustable. Does anyone know how to adjust the volume in the 2011 Edge? My Edge is equipped with the MyFord Touch system if that helps.
Thanks!
Did you check the blinker fluid? It might be low......
Seriously though - I don't believe there is a blinker volume adjustment. If there it would be in the owner's manual.
I used a synthetic blend blinker fluid which is what Ford suggests. Will using full synthetic void my warranty........I can't afford to pay for a blinker bulb since it won't be covered under warranty ?
Should be fine, plus you can go longer in between changes. And they should blink faster, too!
