Cabin Air Filter -- possible to add?
Our new Edge does not have the cabin air filter option.
Anybody know if it is possible to install one?
Parts needed? Where does it go?
Thanks
Yes it can be done.
Cabin Air Filter
A cabin air filter is available as standard equipment on dual-zone EATC vehicles. EMTC vehicles are not equipped from the factory with a cabin air filter, but are equipped with a screen in place of the filter to prevent any large foreign material from entering the heater core and evaporator core housing. The cabin air filter or screen can be accessed by removing the glove compartment and removing the cabin air filter access cover.
A cabin air filter can be installed as a dealer accessory on vehicles not originally equipped with a filter, but only a screen or a filter should be installed, never both.
Filter is located behind the glove box
Yes it can be done.
Cabin Air Filter
Super! Thanks for the info
  • 3 years later...
Hello! What is an "EATC" and/or an "EMTC" vehicle?
Where do you find out what you have?
I have a 2008 Edge SEL ... with only a screen no filter.
Filter was fairly clean ... no bugs/birds/bats or large objects ... just a bit of dust. Cleaned/replaced/all ok.
It means Electronic Automatic Temperature Control (auto climate control) or Manual temp control.
