Does octane matter?
fisdu
Bought my '08 Edge about a month ago. I did an experiment in my last car and found that it really didn't pay to burn expensive(higher octane) fuel in my Pontiac Grand Prix GT.
I was thinking about doing a similar experiment with my Edge and see if it paid off.
Here is what I did in my car. I took one month and burned each of the octanes (87, 89, 91) keeping track of how much I bought and how much more it was than regular 87 octane. Also, I kept track of the miles I drop giving me the MPG average for each as well as how much more I spent on fuel to get the extra MPG(if any). It turned out that if I did get any increase in MPG it was very small and when compared to the extra money I spent to get the higher octane fuel, it was actually costing me more money per mile to drive than if I had used regular 87 octane fuel.
Has anyone done anything like this with an Edge?
Why waste your time and money? The results will be in favor of the lower octane fuel because the edge engine is designed to run on regular grade gasoline.
I cannot remember the numbers but when I was travelling through Texas and Missouri towing my MC trailer the low grade gas (83 or 85 I think) very definitely gave significantly worse mileage in my 2008. Once ascertained i went to the mid grade that if I remember correctly was was 87 or 88 octane and my mileage came back to normal
Good to know since I live in Missouri.
Thanks for the input.
I helped start up a fuel quality testing regulatory program for my state and learned from the lab guys from the oil companies, and related research, that once a motor is provided with a fuel with an adequate octane number increasing the octane level will have and cannot have any impact on motor performance or efficiency.
The lab guys for the major oil companies assured me that except for octane levels, the various fuels were exactly the same across each brand. In fact, most if not all brands of fuel are provided from the closest refinery source, without regard to brand. What special additives may or may not be added at the fuel terminal before it is distributed I cannot comment on since that was considered to be a trade secret. They assured me that tracers were added so that they could confirm that the brand being dispensed was the same as the brand on the pump, but again they would not share the details with the reguator agency.
In my opinion, if the motor does not ping or knock, there is little if anything to be gained by using a higher octane fuel.
By the way, in my state I helped slip into the fuel quality law that each station pump also had to post the cetane level for diesel fuel.
Richard
Using a higher octane than recommended typically won't help, but there are some exceptions.
Some vehicles have computer programming that advances the engine timing for better performance. When you advance the engine timing you usually have to increase the octane to compensate. These vehicles will usually be advertised as Premium Fuel recommended (as opposed to required).
Akirby, isnt the new mustang/edge 3.7 motor designed this way? I seem to remember reading that during the development this was talked about. The timing would advance until knock sensors detected knock. Obviously that would be directly related to octane rating. This was an "on-demand" type of performance enhancement built into the motor. I'll keep searching for the article to post here, unless someone finds it before me. Or maybe I'm confusing issues?
Ok, here is what I read about the 3.7 motor. The specific paragraph is next to the photo of the rear of the mustang on page 2.
http://www.musclemustangfastfords.com/tech/mmfp_1006_2011_ford_mustang_37l_v6_engine/37l_v6_engine.html
Edited by Edgieguy
  On 2/11/2011 at 6:52 PM, ThinLine said:
Once the knock sensors are triggered, the cpu retards the timing.
But as Edgieguys link describes, Ford's latest tuning goes a step further and will advance timing until the knock sensors are triggered. Thus there is a performance benefit to running higher octane, though it still may not pay off considering the higher cost per gallon.
The 2011 Edge has this strategy, but the 2008 of the OP does not.
  On 2/11/2011 at 11:38 PM, ThinLine said:
Knock sensors IMHO, are as useless as tits on a nun. They should save the cost of the sensors and install and install side mirror turn signal indicators.
If you want to burn some holes in your nun's tits, disable her knock sensors--- you can't hear all detonation-- and, I do believe that 87 octane is the recommended grade for the edge.
As far as I know, and I have traveled this whole state, there is no grade of fuel below 87 octane available in Texas. Colorado, yes, and possibly some parts of New Mexico, but I've never seen anything lower than 87 in Texas!
Depends on the elevation, in the panhandle (Amarillo and surrounding area) where the elevation is 3000 feet and above you will find 85 and 86 and most premium is 91 instead of 93. Lived in that area for 30 + years and 93 was semi-hard to find in the last few years before I moved. And it appears to be spreading, about a month ago I made a trip in that direction I ran into the lower octane (86) gas in my home town which is around 1850 feet.
Edited by curlysir
I lived in Lubbock for several years and am now in Houston--- I sure don't remember seeing anything less than 87 till I got into the New Mexico highlands--- but, when you get much above 3000 ft., the engine that required 87 at sea level only requires something less to produce a normal run without detonation.
http://lubbockonline.com/stories/101809/col_506046607.shtml
It was phased in over a period of time. I left the panhandle about 5 years ago. Before I left 93 octane premium was hard to fine, only a few stations carried it. And the 87 was being replaced with the 85 - 86 octane stuff.
Lubbock is about the same elevation as Amarillo, and as the article your referenced, 86 is the standard there. Went to school at Tech and back then we could get the good stuff, 100 octane, at the pumps :yup: .
My home town is about 120 miles east of Lubbock, and last month when I filled up the regular was 86 octane.
Ya got one of those old bumper stickers that says,"Lucky Me, I'm leaving Lubbock!"-- They came out right after the ones that said, "Lucky me I live in Lubbock." :hysterical:
  • 5 months later...
  On 7/25/2011 at 1:50 PM, TomSm said:
Is there any truth in the old saying, that using a higher octaine once or twice a year helps keep the plugs clean???
None whatsoever. That was based on the old practice of only putting detergents in premium fuel. Back then it did make a difference but today all grades get detergents and the only reason to use premium is to either prevent knocking (which means something is wrong with your engine) or in some vehicles to unlock a little more power and mpg - but only if the vehicle is specifically designed to advance the engine timing to take advantage of the higher octane. These vehicles are usually designated as "premium recommended" as opposed to premium required or they specifically state that premium will add more power.
Otherwise using premium in a vehicle designed for 87 is a complete waste of money.
Top Tier Detergent Gasoline
TOP TIER Detergent Gasoline is the premier standard for gasoline performance. Six of the world's top automakers, BMW, General Motors, Honda, Toyota, Volkswagen and Audi recognize that the current EPA minimum detergent requirements do not go far enough to ensure optimal engine performance.
Since the minimum additive performance standards were first established by EPA in 1995, most gasoline marketers have actually reduced the concentration level of detergent additive in their gasoline by up to 50%. As a result, the ability of a vehicle to maintain stringent Tier 2 emission standards have been hampered, leading to engine deposits which can have a big impact on in-use emissions and driver satisfaction.
These automakers have raised the bar. TOP TIER Detergent Gasoline help drivers avoid lower quality gasoline which can leave deposits on critical engine parts, which reduces engine performance. That's something both drivers and automakers want to avoid. Marty
TOP TIER Detergent Gasoline Retailers
Gasoline retailers must meet the high TOP TIER standards with all grades of gasoline to be approved by the automakers as providing TOP TIER Detergent Gasoline.
In addition, all gasoline outlets carrying the brand of the approved retailer must meet the TOP TIER standards.
Additional gasoline retailers are added to the TOP TIER list as they meet the standards. The retailers known to be on the TOP TIER list are shown below.
TOP TIER Gasoline Retailers:
USA Canada
76 Stations Chevron Canada
Aloha Petroleum Esso
Chevron PetroCanada
Conoco Shell Canada
Country Mark Sunoco Canada
Entec Stations
Exxon
Holiday Stationstores, Inc.
Kwik Trip / Kwik Star
MFA Oil Co.
Mileage Stations
Mobil
Phillips 66
Quik Trip
Rebel Oil
Road Ranger
Severson Oil
Shell
Texaco
The Somerset Refinery, Inc.
Tri-Par Oil Co.
U.S. Oil
Marty
All the more reason to not buy their cars! :stirpot:
