vertcobra99 Posted February 10, 2011 Report Share Posted February 10, 2011 Hi guys I have just over 1900 miles on my new edge. Everything is great since the sync gen 2 upgrade accept one thing... When I set the vents to blow air through both the lower and upper vents at the same time. It sounds like its blocked makes a big whiring noise. No air comes out through the bottom and only a small amount of air comes out through the main vents even if the fan makes a lot of noise....almost sounds as if its blocked. But if I want air through just the bottom or just the main vents it works fine and no whiring noise. Which makes me think its blocked when its on both at the same time. Has this happened to anyone else or has anyone else noticed this problem? I am going to take the car to the dealer but I wanted to double check to see if it was something that I could fix on my own first. Thanks, Quote Link to comment Share on other sites More sharing options...
ThinLine Posted February 10, 2011 Report Share Posted February 10, 2011 (edited) Sounds like the actuator or "trap door" is malfunctioning. Maybe something is blocking the door but it's strange that it works fine when not splitting the air flow. Service appointment time.........good luck ! BTW, how's the Cobra running ?.......I own a 2004 Mystichrome Cobra convertible. Edited February 10, 2011 by ThinLine Quote Link to comment Share on other sites More sharing options...
vertcobra99 Posted February 10, 2011 Author Report Share Posted February 10, 2011 Sounds like the actuator or "trap door" is malfunctioning. Maybe something is blocking the door but it's strange that it works fine when not splitting the air flow. Service appointment time.........good luck ! BTW, how's the Cobra running ?.......I own a 2004 Mystichrome Cobra convertible. I actually sold it before winter... I have had my eye on a 2011 GT500 for a while... I might pull the trigger this spring time. Quote Link to comment Share on other sites More sharing options...
ThinLine Posted February 10, 2011 Report Share Posted February 10, 2011 I actually sold it before winter... I have had my eye on a 2011 GT500 for a while... I might pull the trigger this spring time. You might want to hold out for the 2012 Boss 302 Laguna seca edition. Quote Link to comment Share on other sites More sharing options...
vertcobra99 Posted February 16, 2011 Author Report Share Posted February 16, 2011 You might want to hold out for the 2012 Boss 302 Laguna seca edition. Na I don't think so... the boss is only going to be 430 ish HP... I'll take a supercharged 5.4L with 550hp Quote Link to comment Share on other sites More sharing options...
ThinLine Posted February 16, 2011 Report Share Posted February 16, 2011 Na I don't think so... the boss is only going to be 430 ish HP... I'll take a supercharged 5.4L with 550hp It's actually 445 horse which is underated by about 20 horses. If you think about it...not only is the cobra supercharged but it has a 5.4 liter which makes only 100 more horses than a naturally aspirated 5.0. Don't get me wrong....cobra is king and carroll shelby is a god.....hell, my wife is pregnant and if it's a girl her name is going to be Shelby ! 5he cobra is a much heavier vehicle and I suspect 1/4 mile times will be very similar. However, on the twistys the boss will leave the cobra in the dust. Just something to think about. Quote Link to comment Share on other sites More sharing options...
