ncford Posted February 9, 2011 Report Share Posted February 9, 2011 I got my 2011 Edge 4 weeks ago and today I had the message "Vehicle in Transport Mode' on the cluster message center. I can't get past that message to the normal screen with radio stations, temperature etc... Anybody know how to exit this? thanks Quote Link to comment Share on other sites More sharing options...
krash67 Posted February 9, 2011 Report Share Posted February 9, 2011 I got my 2011 Edge 4 weeks ago and today I had the message "Vehicle in Transport Mode' on the cluster message center. I can't get past that message to the normal screen with radio stations, temperature etc... Anybody know how to exit this? thanks Unfortunately you can't. You will have to take it back to the dealer to unlock the whole SYNC system. I received the same message when I got my Edge and the dealer forgot to do a Pre-Delivery Inspection on it. I am curious to find out how it revert back to Pre-delivery state. Quote Link to comment Share on other sites More sharing options...
Waldo Posted February 10, 2011 Report Share Posted February 10, 2011 (edited) Transport mode will end after 50 miles. If it's come back then something is really messed up. Also this was the procedure to turn it off on some of the older Ford's, not sure if it will still work on the 2011 Edge: Turn ignition to Run Press brake pedal 5 times Press Hazard switch 4 times Turn ignition to Off Edited February 10, 2011 by Waldo Quote Link to comment Share on other sites More sharing options...
ncford Posted February 10, 2011 Author Report Share Posted February 10, 2011 Transport mode will end after 50 miles. If it's come back then something is really messed up. Also this was the procedure to turn it off on some of the older Ford's, not sure if it will still work on the 2011 Edge: Turn ignition to Run Press brake pedal 5 times Press Hazard switch 4 times Turn ignition to Off Thanks. I actually tried this a few times, but didn't work. I also read that it comes off after 75 miles, so I may just wait and see if it disappears. If not, I'll go to the dealer. Quote Link to comment Share on other sites More sharing options...
WPNZ Posted February 12, 2011 Report Share Posted February 12, 2011 Thanks. I actually tried this a few times, but didn't work. I also read that it comes off after 75 miles, so I may just wait and see if it disappears. If not, I'll go to the dealer. The above sequence is correct, but you have to do it pretty fast, I think its like turning the hazards on and off twice within 10-15 sec after you press the brake. Quote Link to comment Share on other sites More sharing options...
mvp6002 Posted April 24, 2011 Report Share Posted April 24, 2011 I tried this sequence today and it worked. The truth is that pressing the Hazard switch 4 times is very difficult in the allowed time in order for it to work properly. I tried about 15 time until it finally worked. A sign that it worked is that the horn will honk automatically once when you press the hazard for the third time and once more when you turn the ignition switch to off. Thanks again! Quote Link to comment Share on other sites More sharing options...
CrssrdsSalesguy85 Posted May 19, 2011 Report Share Posted May 19, 2011 I tried this sequence today and it worked. The truth is that pressing the Hazard switch 4 times is very difficult in the allowed time in order for it to work properly. I tried about 15 time until it finally worked. A sign that it worked is that the horn will honk automatically once when you press the hazard for the third time and once more when you turn the ignition switch to off. Thanks again! Ok, I am a Ford Vehicle sales counselor, and I admit, due to the fact that I just started selling, had no idea how to remove that notification. After reading this forum, and through trial-error I figured out the sequence. In order to remove this notification, you must turn the key to run, apply the brakes 5 times, and hit the hazard button six times. The speed at which you do so is un important. I hit the hazard about once every half second or so. Once you hit the hazard the sixth time, the horn will sound once. After you turn the key off, the horn sounds twice. Turn the vehicle back on, and it should be cleared. Thank you for reading. Quote Link to comment Share on other sites More sharing options...
SuesEdge Posted October 26, 2011 Report Share Posted October 26, 2011 Our Edge went into this mode this morning. Plus none of the touch buttons on the center cluster work. As a result, the "fix" of tapping the brake 5 times and the hazard warning 4 or 6 times won't work. The capacitive touch hazard button doesn't work, nor do the radio or temperature controls. Everything works from the steering wheel cluster, however. Ford just got badly dinged from Consumer Reports for issues with its Sync system. We've been pretty happy with it until now, but I can see how issues like this drive customers nuts! Relying upon Microsoft for a vehicle operating system appears to have been a mistake! Quote Link to comment Share on other sites More sharing options...
akirby Posted October 26, 2011 Report Share Posted October 26, 2011 Our Edge went into this mode this morning. Plus none of the touch buttons on the center cluster work. As a result, the "fix" of tapping the brake 5 times and the hazard warning 4 or 6 times won't work. The capacitive touch hazard button doesn't work, nor do the radio or temperature controls. Everything works from the steering wheel cluster, however. Ford just got badly dinged from Consumer Reports for issues with its Sync system. We've been pretty happy with it until now, but I can see how issues like this drive customers nuts! Relying upon Microsoft for a vehicle operating system appears to have been a mistake! For the 700th time - it's not microsoft, it's the application code! Quote Link to comment Share on other sites More sharing options...
evil77 Posted November 24, 2011 Report Share Posted November 24, 2011 I have had a myriad of problems with My Ford Touch. The dealer knows my vechicle very well. I have 22,000 miles on the vehicle and today it went into transport mode. I tried the "fix". I got two beeps then it said I need to Train the front left tire. I'm a technology person and the Edge is not making me very happy. I have an appointment with the dealer on Black Friday. Makes me wonder if I should have bought the Audi Q5. I really like my Edge, but this is getting old. Quote Link to comment Share on other sites More sharing options...
