JDFord Posted February 7, 2011 Report Share Posted February 7, 2011 I have a 2009 Ford Edge Limited and I have really enjoyed having the keyless entry. I have been using this feature for a while until this past weekend when the same factory code no longer works. The key pad still locks the doors, and all the buttons light up when one is hit, so it registers, but the code no longer works. Has this happened to anyone else or does anyone have any advice other than going to the dealer? Thanks Quote Link to comment Share on other sites More sharing options...
akirby Posted February 7, 2011 Report Share Posted February 7, 2011 I have a 2009 Ford Edge Limited and I have really enjoyed having the keyless entry. I have been using this feature for a while until this past weekend when the same factory code no longer works. The key pad still locks the doors, and all the buttons light up when one is hit, so it registers, but the code no longer works. Has this happened to anyone else or does anyone have any advice other than going to the dealer? Thanks Hate to sound so obvious, but are you sure you're using the right code? Did you check the card in the glovebox? If so then you may have one bad button. Try each one to see if it lights up the display. Quote Link to comment Share on other sites More sharing options...
