Edgar Edgeworthy Posted January 31, 2011 Report Share Posted January 31, 2011 My 2011 LTD is releasing smoke (and/or steam) from the exhausts in temperatures of about 50-60 degrees. Is this normal? Quote Link to comment Share on other sites More sharing options...
Edgar Edgeworthy Posted January 31, 2011 Author Report Share Posted January 31, 2011 Am also experiencing some liquid dripping from exhausts. Quote Link to comment Share on other sites More sharing options...
choff1138 Posted January 31, 2011 Report Share Posted January 31, 2011 My 2011 LTD is releasing smoke (and/or steam) from the exhausts in temperatures of about 50-60 degrees. Is this normal? Interesting - I hope not, but couldn't confirm if mine does that. It has been below 50 the whole time I have owned mine. Quote Link to comment Share on other sites More sharing options...
akirby Posted January 31, 2011 Report Share Posted January 31, 2011 My 2011 LTD is releasing smoke (and/or steam) from the exhausts in temperatures of about 50-60 degrees. Is this normal? Some steam and dripping is definitely normal especially after it's first started. If it does it constantly and in low humidity then you might need to get it checked out. Quote Link to comment Share on other sites More sharing options...
ebank Posted January 31, 2011 Report Share Posted January 31, 2011 In cooler weather condensation will collect on the inside of the exhaust, as the exhaust heats after the engine is started, the condensation will drip out of the exhaust tip or turn into a vapor making your exhaust fumes visible. Quote Link to comment Share on other sites More sharing options...
curlysir Posted February 1, 2011 Report Share Posted February 1, 2011 (edited) In cooler weather condensation will collect on the inside of the exhaust, as the exhaust heats after the engine is started, the condensation will drip out of the exhaust tip or turn into a vapor making your exhaust fumes visible. What he said!!! Perfectly normal, when the temperature and humidity are just right you will get visible vapor and condensate with dripping. Every car I have owned has done this! When the exhaust warms up the vapor may or may not be visible but the dripping will stop. Edited February 1, 2011 by curlysir Quote Link to comment Share on other sites More sharing options...
