Finally arrived--some questions
donway
2011 SEL AWD arrived two months after ordering. Love the Earth Metallic color.
Do others notice low beam headlights are very low, can only see out the bottom half of windshield?
Mirrors and pillars create blind spots when turning and rear seat headrests in way when backing up?
Does it take awhile for MPG display to read accurately? It started out about 6 mpg and 100 miles later I am up to 11 mpg.
Sync seems to be working OK
The headlights are typically aimed too low from the factory. Check the OM for adjustment procedure.
Try resetting the average MPG every time you fill up (at least). Mileage will improve over the first few thousand miles then level off. Also note that you'll have winter blend fuel for the next few months if you're in a cold state.
