msoneil Posted January 22, 2011 Report Share Posted January 22, 2011 i replaced the battery on my 07 edge and broke the nuetral clamp on the battery cable had to but whole kit form ford for $170.00 has anyone had to do this or know how to replace the cables? 1 Quote Link to comment Share on other sites More sharing options...
Feirstein Posted January 23, 2011 Report Share Posted January 23, 2011 Why do you not just replace the end clamp? This can be very easy to do and costs a lot less. Any good mechanic would be glad to do this for you. Quote Link to comment Share on other sites More sharing options...
msoneil Posted January 23, 2011 Author Report Share Posted January 23, 2011 Why do you not just replace the end clamp? This can be very easy to do and costs a lot less. Any good mechanic would be glad to do this for you. Quote Link to comment Share on other sites More sharing options...
msoneil Posted January 23, 2011 Author Report Share Posted January 23, 2011 not a normal end clamp the nuetral goes through it and to the frame ground I was told by a ford mechanic not to try and cut the wire and retrofit it Quote Link to comment Share on other sites More sharing options...
shantanu Posted May 11, 2011 Report Share Posted May 11, 2011 Hi All,This weekend, I used a air blower to cleen My Ford Edge (2007) under bonnet. Now I found ,my left side back door glass switch on driver's pannel only able to wind down the glass but could not wind up. But from the back door it can do both. So some where a cable got loose or a fuse blown by my air blower.Can any one help me with a electrical diagram copy so I can do it myself. Thanks.Shantanu Quote Link to comment Share on other sites More sharing options...
