rknutson Posted January 4, 2011 Report Share Posted January 4, 2011 will the 2011 tail lights fit or work with 2007 Quote Link to comment Share on other sites More sharing options...
Edgieguy Posted January 5, 2011 Report Share Posted January 5, 2011 will the 2011 tail lights fit or work with 2007 Side by side next to my 2008 Id say yes. They were so close I couldnt see a difference by eye. Before you buy a set, trace your tails on a sheet of paper, and then take a trip to the dealership and line it up against a 2011 light. All the attachment bolts are exactly the same, which makes sense since the entire body structure is the same from 2007, including the doors and rear latch. Quote Link to comment Share on other sites More sharing options...
Depiry Posted January 5, 2011 Report Share Posted January 5, 2011 Looking at them without measuring it seems close,they will require some wiring changes for the 2 stop and tail lamps,replacement of the flasher to a 3 lamp unit Marty, Quote Link to comment Share on other sites More sharing options...
