Adding in the LED Lights on Front Panel
HS2020
Just bought a 2011 SE that has some of the SEL options which is nice. The one thing I really like is the LED lighting on the front. Ours does not have this. I know there will be some Edges going to the junk yard with in the next year. I hope they don't but it happens. What I want to do is get these lights and add them to the front. How hard would this be and should I let the dealer do it so as the warranty does not come into question. Like I said we just bought it. It has maybe a 100 miles on it. Bought it with 5 miles on it on Friday 31 Dec 2010. Thanks and if this is in the wrong place Admins/MODS please move to correct forum.
Here try this.
Install Ambient Lighting.pdf
Yes but those would be nice as well. The wiring should be in place as all models use the same wiring harness pretty much. So when and if I add in the LEDs to the front of the Edge should not be a problem.
You would be wrong ,they have diffrent harnesses for diffrent options .They don't the use same looms for all the Edges
Edited by 07CRUSH
