HodagEdge Posted January 2, 2011 Report Share Posted January 2, 2011 What do you know about Cam Phasers? I need mine replaced. Pros vs Cons? Quote Link to comment Share on other sites More sharing options...
akirby Posted January 2, 2011 Report Share Posted January 2, 2011 What do you know about Cam Phasers? I need mine replaced. Pros vs Cons? I know they're required to make the engine run correctly. An out of phase Camshaft can't be good. Quote Link to comment Share on other sites More sharing options...
TerryTwoUtes Posted January 5, 2011 Report Share Posted January 5, 2011 (edited) I know they are sensitive to oil viscosity, to work correctly you need to run the 5w-20 oil. Such as the Motorcraft oil you can get at Wal Mart. Also know that it is a failry big job to replace them, if not under warranty it could be a big repair expense. Edited January 5, 2011 by TerryTwoUtes Quote Link to comment Share on other sites More sharing options...
HodagEdge Posted January 9, 2011 Author Report Share Posted January 9, 2011 Thanks for the feedback. Everything I hear is what you mentioned. It is expensive and takes about 1 week. Thank goodness itisstill under warranty. Quote Link to comment Share on other sites More sharing options...
