phdedgeman Posted December 26, 2010 Report Share Posted December 26, 2010 (edited) I have the iPhone 4 and it works wonderfully with the 2011 Edge Limited sound system when plugged into the USB port. The iPhone (for phone calls) also works perfectly wirelessly with the stereo system. BUT the BTStereo doesn't typically work wirelessly with the music on the iPhone. When I push the BTstereo label, it says it's connecting to my iPhone (even though the iPhone was already connected wirelessly for phone use) but never does. Any suggestions? Thanks in advance. Edited December 26, 2010 by phdedgeman Quote Link to comment Share on other sites More sharing options...
Tulsa Posted December 26, 2010 Report Share Posted December 26, 2010 You need to get the update from your dealer. I was having the same issue, got the update, it's all fine now. Quote Link to comment Share on other sites More sharing options...
phdedgeman Posted December 27, 2010 Author Report Share Posted December 27, 2010 You need to get the update from your dealer. I was having the same issue, got the update, it's all fine now. Thank you. I'll do just that. Quote Link to comment Share on other sites More sharing options...
johnl327 Posted December 28, 2010 Report Share Posted December 28, 2010 to get the iphone 4 bt miusic to work i touched where it said source until the music came on and blue tooth label came up on the upper right side of the screen Quote Link to comment Share on other sites More sharing options...
wilsons66604 Posted December 29, 2010 Report Share Posted December 29, 2010 to get the iphone 4 bt miusic to work i touched where it said source until the music came on and blue tooth label came up on the upper right side of the screen The Touch update shuold simplify the BT Audio process Quote Link to comment Share on other sites More sharing options...
