phdedgeman Posted December 26, 2010 Report Share Posted December 26, 2010 There appear to be three options to getting directions from point a to point b: the navigation system, Mysync or Sirius. Which do you folks recommend and why? Thanks in advance. Quote Link to comment Share on other sites More sharing options...
akirby Posted December 26, 2010 Report Share Posted December 26, 2010 There appear to be three options to getting directions from point a to point b: the navigation system, Mysync or Sirius. Which do you folks recommend and why? Thanks in advance. Moved her from the Welcome forum. If you have the Nav system you don't get sync turn by turn directions - it's one or the other. Always use Nav - that's why you bought it and you get the map, etc. I don't think Sirius gives you turn by turn directions. Quote Link to comment Share on other sites More sharing options...
phdedgeman Posted December 27, 2010 Author Report Share Posted December 27, 2010 (edited) Moved her from the Welcome forum. If you have the Nav system you don't get sync turn by turn directions - it's one or the other. Always use Nav - that's why you bought it and you get the map, etc. I don't think Sirius gives you turn by turn directions. Thank you akirby. As per your suggestion, the Nav does make the most sense. Now if only I could get my iPhone 4 to work wirelessly with the BT Stereo. Any suggestions? Edited December 27, 2010 by phdedgeman Quote Link to comment Share on other sites More sharing options...
akirby Posted December 27, 2010 Report Share Posted December 27, 2010 Thank you akirby. As per your suggestion, the Nav does make the most sense. Now if only I could get my iPhone 4 to work wirelessly with the BT Stereo. Any suggestions? If you have a 2011 then get the Sync/MFT update (tell the dealer you're having bluetooth problems). Then make sure you have the latest iphone OS software. Finally, try deleting and repairing the phone. Quote Link to comment Share on other sites More sharing options...
e-Mel Posted January 8, 2011 Report Share Posted January 8, 2011 Moved her from the Welcome forum. If you have the Nav system you don't get sync turn by turn directions - it's one or the other. Always use Nav - that's why you bought it and you get the map, etc. I don't think Sirius gives you turn by turn directions. You actually get both. Sync's turn by turn directions are downloaded to your car via your cellphone and can then be added to your nav's screen. I've done this on occasion while driving and the nav database didn't recognize the spoken address. Quote Link to comment Share on other sites More sharing options...
