cant keep phone paired
Hi guys
I get my samsung instinc paired but after 2-3 minutes in drops my phone. Only once it worked for about 1 hour. Everything else works perfectly. Im hesitant to go to Ford as I heard so many scary storys of them trying to update softwear...
Has anyone had problems keeping cel phone paired?
Try pulling the phone battery and repairing it first. If that doesn't work pull fuse #29 to reset Sync.
Remove all variables and work backwards in assessing whats wrong. Which item is more valuable to you if you lost the data, the phone or the sync? More than likely, the phone data is more valuable so work from that understanding. As akirby said, try reseting, then try pulling battery. If that does not work, master reset ford sync (via the menu system). If that doesnt work, master reset again and pull fuse #29. If that doesnt work, factory reset your phone and the myFord touch.
Hi guys
Edited by Stryprod
