akirby Posted February 13, 2012 Author Report Share Posted February 13, 2012 Already got one of those...no change. But I am wondering if Ford uses re-manufactured components for warranty work. So they pull mine bench test it, reload software and send it back out. So maybe those of us that had it replaced actually got one that was a problem before?? Not sure what to think. Possible but I think it's more likely that there is just a bad batch of them and they're not bad enough that it fails completely. Or as suggested earlier it could just be some combination of usage that hits more of the bugs for some people than others. It could be as simple as whether you use seat heaters or not that uses a different part of the code and that triggers more faults. I've seen some pretty strange things in my 25 years in IT. The good news is that once the update is out then continued problems would point more towards hardware and should make it easier to resolve. Right now they just don't know whether it's hardware or software. Quote Link to comment Share on other sites More sharing options...
richy Posted February 13, 2012 Report Share Posted February 13, 2012 Had the wife's MKS in thisn past week for LOF & tire rotation, talking with the Service tech about problems people are having, he said until the update isn out, disconnect the Postive(red) battery cable for 5-10 minutes, not just a few seconds or 1 minute. He said that, like a computer, every app should shut down completely before reconnecting (reboot). This dealership ( Maplecrest ) is the same one that helped out another forum member out in 'Vegas, who's dealership had no idea about the program rewrite for the rear liftgate. Joe, you and I have conflicting advice. One day when I was driving to work I got the black screen of death. I was not able to bring it in to the dealer so they sent a tech out to my work to look at it. He disconnected the negative lead and left it off for a minute or two (maybe longer, I don't remember). I wrote down what he did in case I needed to do it again on my own. After reading your post, I called the dealer and spoke to a employee who went and asked the same tech which lead it was. He confirmed it was negative. Can you double check with your dealer? Quote Link to comment Share on other sites More sharing options...
akirby Posted February 13, 2012 Author Report Share Posted February 13, 2012 Joe, you and I have conflicting advice. One day when I was driving to work I got the black screen of death. I was not able to bring it in to the dealer so they sent a tech out to my work to look at it. He disconnected the negative lead and left it off for a minute or two (maybe longer, I don't remember). I wrote down what he did in case I needed to do it again on my own. After reading your post, I called the dealer and spoke to a employee who went and asked the same tech which lead it was. He confirmed it was negative. Can you double check with your dealer? You're always supposed to disconnect the negative lead for safety reasons. If, while disconnecting the negative battery lead you accidentally touch a grounded part of the car - nothing happens. But if you're disconnecting the positive lead and accidentally touch a grounded part of the car you just completed the circuit. There is no difference which one you disconnect electrically speaking - both work, but using the neg. cable is much safer. Quote Link to comment Share on other sites More sharing options...
wlepse Posted February 13, 2012 Report Share Posted February 13, 2012 Possible but I think it's more likely that there is just a bad batch of them and they're not bad enough that it fails completely. Or as suggested earlier it could just be some combination of usage that hits more of the bugs for some people than others. It could be as simple as whether you use seat heaters or not that uses a different part of the code and that triggers more faults. I've seen some pretty strange things in my 25 years in IT. The good news is that once the update is out then continued problems would point more towards hardware and should make it easier to resolve. Right now they just don't know whether it's hardware or software. Doubtful it could be a bad batch. I thought most of the manufacturers were doing JIT/FIFO manufacturing so if my Edge was made a year ago that batch would be long gone by now. I have designed/installed tons of automated industrial equipment over the years with far more complicated software than this, so I know what you mean by finding some strange bugs. But with that said our MFT is only controlling radio and HVAC at this point. No phones are paired and with the exception of this weekend I don't bother with the nav. But I can't believe there could be bugs in this portion of the code since it would mean everyone would have the problems. Besides, often we are greeted with a black or locked screen on start up before anything has been touched. Quote Link to comment Share on other sites More sharing options...
akirby Posted February 13, 2012 Author Report Share Posted February 13, 2012 Doubtful it could be a bad batch. I thought most of the manufacturers were doing JIT/FIFO manufacturing so if my Edge was made a year ago that batch would be long gone by now. I have designed/installed tons of automated industrial equipment over the years with far more complicated software than this, so I know what you mean by finding some strange bugs. But with that said our MFT is only controlling radio and HVAC at this point. No phones are paired and with the exception of this weekend I don't bother with the nav. But I can't believe there could be bugs in this portion of the code since it would mean everyone would have the problems. Besides, often we are greeted with a black or locked screen on start up before anything has been touched. I understand and agree. Could also be wiring or connectors......... 1 Quote Link to comment Share on other sites More sharing options...
wlepse Posted February 13, 2012 Report Share Posted February 13, 2012 I understand and agree. Could also be wiring or connectors......... Whatever it is I hope it gets fixed and quick. Quote Link to comment Share on other sites More sharing options...
JOEHIO Posted February 14, 2012 Report Share Posted February 14, 2012 Joe, you and I have conflicting advice. One day when I was driving to work I got the black screen of death. I was not able to bring it in to the dealer so they sent a tech out to my work to look at it. He disconnected the negative lead and left it off for a minute or two (maybe longer, I don't remember). I wrote down what he did in case I needed to do it again on my own. After reading your post, I called the dealer and spoke to a employee who went and asked the same tech which lead it was. He confirmed it was negative. Can you double check with your dealer? Hey Richy, I was right there when they disconnected/reconnedted the posative cable, when I thought I had a problem with the car, and it actually was a problem with my Ipod. I'll call them tomorrow to see what they say on this, will add a post asap. Joe Quote Link to comment Share on other sites More sharing options...
akirby Posted February 14, 2012 Author Report Share Posted February 14, 2012 Hey Richy, I was right there when they disconnected/reconnedted the posative cable, when I thought I had a problem with the car, and it actually was a problem with my Ipod. I'll call them tomorrow to see what they say on this, will add a post asap. Joe Joe - it works fine but it's not the safest way to do it for the reasons I already described. It's much safer to use the negative cable. I'd steer clear from a mechanic who didn't know this. Quote Link to comment Share on other sites More sharing options...
Fuel_md Posted February 19, 2012 Report Share Posted February 19, 2012 Quick question..I bought my Edge two weeks ago, love it so far..When I registered my Sync online, it said that there was an update available for my vehicle..I went to the dealership and asked about getting the update and I was told that they don't do an update unless there is a problem with the system I currently have.. I don't have any issues, but if there is an update out there, shouldn't I be getting it??..It didn't make sense to me..Just thought I'd ask to see if the dealership gave me the right answer.. Quote Link to comment Share on other sites More sharing options...
ladybird4 Posted February 19, 2012 Report Share Posted February 19, 2012 Quick question..I bought my Edge two weeks ago, love it so far..When I registered my Sync online, it said that there was an update available for my vehicle..I went to the dealership and asked about getting the update and I was told that they don't do an update unless there is a problem with the system I currently have.. I don't have any issues, but if there is an update out there, shouldn't I be getting it??..It didn't make sense to me..Just thought I'd ask to see if the dealership gave me the right answer.. What they told you was correct. Because ford makes you jump through hoops to get things done you have to be experiencing a problem. Give it a day and you shoud experience one glitch and they will then do it for free. It's a Ford thing not a dealer thing. You always have the option of downloading the update and doing it yourself. Remember if you ask it to place a call and it does not understand you that is a problem. It's a shame you have to stretch the truth to get Ford to pay the dealer so they will do it for you. My 2011 was shipped with 2.7 dealer has upgraded it to 2.8 and then to 2.11 i have very few problems with my system. Enjoy your system. Quote Link to comment Share on other sites More sharing options...
Fuel_md Posted February 20, 2012 Report Share Posted February 20, 2012 What they told you was correct. Because ford makes you jump through hoops to get things done you have to be experiencing a problem. Give it a day and you shoud experience one glitch and they will then do it for free. It's a Ford thing not a dealer thing. You always have the option of downloading the update and doing it yourself. Remember if you ask it to place a call and it does not understand you that is a problem. It's a shame you have to stretch the truth to get Ford to pay the dealer so they will do it for you. My 2011 was shipped with 2.7 dealer has upgraded it to 2.8 and then to 2.11 i have very few problems with my system. Enjoy your system. Thanks for clarifying that..Wow, I thought Ford's customer service was top notch!!..I had an 05' Mazda RX-8 and I was totally impressed with their customer service..Hmmmm Ut ohhhh, for some reason my Sync isn't recognizing my voice!!..Rats!!..(Wink Wink) Quote Link to comment Share on other sites More sharing options...
choff1138 Posted February 20, 2012 Report Share Posted February 20, 2012 Thanks for clarifying that..Wow, I thought Ford's customer service was top notch!!..I had an 05' Mazda RX-8 and I was totally impressed with their customer service..Hmmmm Ut ohhhh, for some reason my Sync isn't recognizing my voice!!..Rats!!..(Wink Wink) If your system is working fine - you may not want to upgrade to the newer version. The re-write is coming "soon", but the old saying of if it isn't broke - don't fix it, is very true with this system. Good luck. Quote Link to comment Share on other sites More sharing options...
1duFos Posted February 20, 2012 Report Share Posted February 20, 2012 (edited) Whatever it is I hope it gets fixed and quick. from an article in the USA Today dated Feb 8/12 for your reading pleasure http://www.usatoday.com/money/autos/story/2012-02-07/ford-mytouch/53014836/1 Edited February 20, 2012 by 1duFos Quote Link to comment Share on other sites More sharing options...
akirby Posted February 20, 2012 Author Report Share Posted February 20, 2012 from an article in the USA Today dated Feb 8/12 for your reading pleasure http://www.usatoday.com/money/autos/story/2012-02-07/ford-mytouch/53014836/1 I think the "about 2 months" comment was based on Ford's previous 1Q estimate (3/30 is "about 2 months" from 2/8) and isn't based on any new information. Quote Link to comment Share on other sites More sharing options...
c_bova Posted February 22, 2012 Report Share Posted February 22, 2012 well my 2012 edge sport seems to have it's first symptoms of 2.11 buggy software today. started car up and I had no audio, i'd push the audio screen and it wouldn't go. so after I came back out from the store my audio started working again, but not the voice button on the steering wheel doesn't work. ughhh Quote Link to comment Share on other sites More sharing options...
YanksWinAgain Posted February 29, 2012 Report Share Posted February 29, 2012 The only issue I have had on my 2012 Edge is... EVERY time about 2-3 minutes into driving the car, the steering wheel controls for the up/down station select stops working for 20-30 seconds. It "stores" the command in memory (or somewhere) and will then execute it 2--30 seconds later. The touch screen station selector will work. So... if I am on Station A, and use the Steering Control to move down to Station B, it will not move until 20-30 secs have elapsed. If, while waiting, I move the Station to B using the touch screen, the radio will tune to Station C eventually (since the "move down" command is buffering or something). Everything else functions well. Have had the car since the end of September. Quote Link to comment Share on other sites More sharing options...
JOEHIO Posted February 29, 2012 Report Share Posted February 29, 2012 Just curious, YanksWinAgain, what dealership did you get your Edge at? I got mu MKX at Maplecrest, over in Union, have a servicde dept that I have been VERY satisfied with. Been with them for 3 1/2 years, since my wife's '09 MKS. Joe Quote Link to comment Share on other sites More sharing options...
YanksWinAgain Posted March 1, 2012 Report Share Posted March 1, 2012 Just curious, YanksWinAgain, what dealership did you get your Edge at? I got mu MKX at Maplecrest, over in Union, have a servicde dept that I have been VERY satisfied with. Been with them for 3 1/2 years, since my wife's '09 MKS. Joe All American in Hackensack. Tried a few others around me (Mahwah Ford and Route 23), but Hackensack had the best price. Haven't tried service yet. Still very low miles. Quote Link to comment Share on other sites More sharing options...
JOEHIO Posted March 1, 2012 Report Share Posted March 1, 2012 You might try and disconnect the neg battery cable for 5 minutes, then reconnecting. This will force the system to reboot when you start back up, will take a minute or 2 to do this. Has solved many problems. You wil need a 10 mm wrench for this. If this doesn;t work, I would go back to the dealer, and get paperwork after your visit, for backup, in case of any problems (hopefully not) down the road. I remember a saying from years ago (being in I.T. for a living) - "To error is human, to really foul things up, requires a computer". (MFT) Quote Link to comment Share on other sites More sharing options...
cv27 Posted March 2, 2012 Report Share Posted March 2, 2012 (edited) You might also want to check this thread: Address book download slows (halts) everything Edited March 2, 2012 by cv27 Quote Link to comment Share on other sites More sharing options...
or8ital Posted March 5, 2012 Report Share Posted March 5, 2012 My voice guidance stopped working on my nav. It's not muted it will lower the volume momentarily on the radio but no voice. Any ideas how to fix that. Quote Link to comment Share on other sites More sharing options...
Dingo Posted March 5, 2012 Report Share Posted March 5, 2012 When the volume drops and it's "talking," turn the volume up. Quote Link to comment Share on other sites More sharing options...
or8ital Posted March 5, 2012 Report Share Posted March 5, 2012 When the volume drops and it's "talking," turn the volume up. That doesn't work. It never actually talks. When I said momentarily less than a second. I tried pushing repeat while turning it up and no changes. Quote Link to comment Share on other sites More sharing options...
MrHappy Posted March 5, 2012 Report Share Posted March 5, 2012 Our has done that twice... I'm guessing within a day or two it'll crash and reboot which resolves the issue (for a while). Can always do a manual reset yourself and it'll come back too. It did "fix itself" once just by stopping, powering off and restarting the car. Quote Link to comment Share on other sites More sharing options...
koakai Posted March 12, 2012 Report Share Posted March 12, 2012 I bought my Edge May 2011 and have had non-stop problems with MFT and Sync. I've taken to the dealer twice - would have been more but I've lived with the problems because my dealer won't give me a loaner even though its all under warranty. The first time they said they installed an "update", the second time they said the system was corrupt - both were temp fixes as the problems came back. Does anyone know if the update that is due any time now will fix the following issues: • Steering wheel controls and voice commands don't work or are delayed first five minutes of driving car • Directions won't download from Sync services - just keeps ringing • Sync services "voice" is barely audible. Turning up volume doesn't work • Screen goes black while driving. Sometimes its followed by "scheduled system maintenance", sometimes not. • Phone doesn't always pair • Playing music via Bluetooth sometimes shows the song/artist info, sometimes doesn't. Sometimes the track info is stuck. I'm so fricken' sick of all the problems and the run around from the dealer. The first time I brought it in the service adviser was clueless about the system. I described my long list of problems and he couldn't translate it to the service ticket and had to correct his descriptions. He then made a snarky comment about his fingers hurting from all the typing like it was my fault. The he calls me later to tell me I need to come back with my phone. WTF? Just pair another phone?? Why didn't he mention that to me before I left? They didn't give me a loaner so I had to get a ride back. I'll NEVER buy another Ford again... this is my first one. I miss my old BMW X3. I paid for all these features and they are pretty useless. Without all the fancy technology, it's just an old crappy Ford! Quote Link to comment Share on other sites More sharing options...
