amysedge Posted December 9, 2010 Report Share Posted December 9, 2010 Has anyone figured out how to make your wallpaper the default screen that appears when you start the car? Quote Link to comment Share on other sites More sharing options...
sboots88 Posted December 9, 2010 Report Share Posted December 9, 2010 Unfortunately, that isn't an option currently available to us. -steve Quote Link to comment Share on other sites More sharing options...
noahjb Posted December 9, 2010 Report Share Posted December 9, 2010 What about this... when you change your menu display settings - say from the four corners split screen to the picture background with no buttons - how do you get that to default when you start the car? Everytime I have changed it, it switches back to the four corners when I start the car back up... Quote Link to comment Share on other sites More sharing options...
wilsons66604 Posted December 9, 2010 Report Share Posted December 9, 2010 What about this... when you change your menu display settings - say from the four corners split screen to the picture background with no buttons - how do you get that to default when you start the car? Everytime I have changed it, it switches back to the four corners when I start the car back up... Nope. That's not an option. That feature didn't make it to the production version Quote Link to comment Share on other sites More sharing options...
HotLap Posted December 19, 2010 Report Share Posted December 19, 2010 Similar issue here...was able to upload pics via the SD card in my camara; however, can't get them to display anywhere? Went to my LFD's mytouch expert and he couldn't figure it out either... Quote Link to comment Share on other sites More sharing options...
emeraldtx Posted December 19, 2010 Report Share Posted December 19, 2010 Similar issue here...was able to upload pics via the SD card in my camara; however, can't get them to display anywhere? Went to my LFD's mytouch expert and he couldn't figure it out either... After they're uploaded, you set the one you want through Menu/Vehicle/Wallpaper (that may be a bit off; doing it from memory). Once you have picked the one you want, then to show it do this: Click the little "house" picture at the bottom of the screen & a slide-up menu will appear. Choose the one on the top that shows one screen. That'll bring your picture up! Unfortunately, you have to do the house/click step each time the car is re-started if you want to use the picture; there isn't any way to set this as the default. Quote Link to comment Share on other sites More sharing options...
